Re: Charger Wheel Opening Moulding Wont Fit New Quarter
[Re: Plum70Chrgr]
#1522909
10/25/13 01:24 PM
10/25/13 01:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Install the qtrs properly, then fit the wheel lip moulding, if need be, used a shrinker/stretcher, to tweak the moulding, or tweak the qtr panel before install....if you don't have a shrinker/stretcher, Eastwood has a decent "backyard" set up for the home hobbiest, invest in it, it'll make fabbing stuff up a lot easier
Mike
[Re: DAYCLONA]
#1522910
10/25/13 01:34 PM
10/25/13 01:34 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I'd reshape the quarter by stretching the edge with a shrinker-stretcher. 15 minute job and it'll be the factory correct shape.
I'm not a body man but this is what my painter said he's had to do before.
Good job on checking these things out now. I cringe when I see posts like this when the car has a fresh coat of paint on it.
[Re: burdar]
#1522911
10/26/13 10:03 AM
10/26/13 10:03 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
The reproduction Charger wheel lip moldings are not made of stainless steel like the originals were. They can be shaped to fit the panels easier than the OEM ones. I was able to shape them to the panels by pressing them with my thumbs. Wear a good pair of gloves while doing it.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: DAYCLONA]
#1522913
10/27/13 08:17 PM
10/27/13 08:17 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
This is close to my experience. Quote:
Install the qtrs properly, then fit the wheel lip moulding, if need be, used a shrinker/stretcher, to tweak the moulding, or tweak the qtr panel before install....if you don't have a shrinker/stretcher, Eastwood has a decent "backyard" set up for the home hobbiest, invest in it, it'll make fabbing stuff up a lot easier. Mike
..... from my '65 Satellite. I got quarter patches from Kramer, my body man spent some time tweaking them for a good fit and profile to the moldings. However, when time came to mount the arch moldings, they didn't fit even as close you show in your pic. I was tired from a long day of working on the car and just wanted it done - so....
...I screwed the "difficult" non-conforming ends in first, then carefully but forcefully moved up the stainless arch molding 'til I had it all on. All four arches needed this treatment, some holes were difficult as #&^%$$, but I got it done and they look fine.
Now I suspect that's how they were treated on the assembly line - just slam them on and get her done!
Best of luck, -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
