Page 2 of 5 1 2 3 4 5
Re: '69 roadrunner w/AC - engine color? [Re: DPelletier] #152192
11/18/08 12:22 AM
11/18/08 12:22 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Owned 2 original, #s, St.Louis '69 RRs with A/C. Turquoise 330-horse, RR pie tin, dual snorkels. Every original #s '69 RR with A/C, regardless of trans, that I researched at the time had the turquoise 330 motor, not the orange 335. Every non-A/C '69 383 I've seen, and I mean hundreds, was the orange 335. The small unsilenced air cleaner was a orange/335 setup, and the dual snorkel was for turquoise/330 motors. Carter carbs on every original '69 RR 383 I've seen, though different model #s depending on trans, A/C, Calif & high altitude (Denver for example). Calif & high-altitude carbs had one central mixture screw. The RR pie tin fits both air cleaners, as did the other pie tins. Magnum was the Dodge marketing name, as previously stated, and would not be found on a Plymouth except by error.
For what it's worth, I've found that some '68s & '69s ran stronger than others, and not necessarily related to the 330/335 rating. For example, my A/C car was stronger than one of my non-A/C cars, and except for the A/C, seats & color they were basically identical. The 335 car "should" have been quicker, but wasn't. My St.Louis-built '68 was quicker & more responsive than my L.A.-built '68 car, too.
Re: '69 roadrunner w/AC - engine color? [Re: topside] #152193
11/18/08 03:17 PM
11/18/08 03:17 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I'm wanting to think that the A/C cars had one with a smaller cam, to help with torque to spin the compressor. That would account for the slightly smaller HP rating.
I don't think it was listed as 330 either in the RR, even if it were different. The marketing numbers staed the same.
Re: '69 roadrunner w/AC - engine color? [Re: SomeCarGuy] #152194
11/18/08 03:33 PM
11/18/08 03:33 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I have a 69 bee with AC and the 899 engine. The engine is turquoise and it came with a 383 four barrel pie tin vs. the 383 magnum one. The block is not stamped HP. Also the carb was a Holley and not a Carter from the factory. It also has a different transmission as well at least by part number to the non ac cars.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: '69 roadrunner w/AC - engine color? [Re: SomeCarGuy] #152195
11/18/08 03:39 PM
11/18/08 03:39 PM
iowa
copchaser Online work
copchaser  Online Work
iowa
I just sold a very origanal 69 Coronet 500, 383HP auto with A/C. It is a numbers matching car, the engine is turquos, and is stamped HP. From what I have found is that the A/C and non A/C engines have the same cam, just a differant distributors, something about the advance curve. A simple look through a factory parts book shows (1) cam number for HP engines, and lots of choices for carbs, and distributors. I have a friend who bought a 70 Challenger 383hp A/C new and still has it. It always has been a dog, I talked him into changing the distributor and wow!! the car is alive and has never run stronger.
Re: '69 roadrunner w/AC - engine color? [Re: copchaser] #152196
11/18/08 03:46 PM
11/18/08 03:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Technically the 383HP wasn't available in the '69 Coronet 500.
... so besides a "HP" stamp, what evidence do you have to support that claim?
B'cast sheet and or Lynch Rd. fender tag numbers?
Re: '69 roadrunner w/AC - engine color? [Re: 6bblgt] #152197
11/18/08 05:29 PM
11/18/08 05:29 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
So is the 899 383 stamped HP or not?
Re: '69 roadrunner w/AC - engine color? [Re: rrunner] #152198
11/18/08 08:46 PM
11/18/08 08:46 PM
Va. Beach, Va
Va. Beach, Va
Well I can tell you my 899 engine is not. Numbers matching and I bought the car from the original owner. Engine assy date is stamped 12 2
Re: '69 roadrunner w/AC - engine color? [Re: 69superbee383] #152199
11/18/08 09:19 PM
11/18/08 09:19 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The spec ad for the 330 hp vs 335 hp 383 engine shows a 200 rpm difference; 330 @ 5000 rpm vs 335 @ 5200 with the same torque but again the 330 hp engine has the max torque 425 lb/ft @ 3200 rpm and the 335 hp's max torque is 425 lb/ft @ 3400 rpm.
It also reads the 335 hp engine has a "high lift, high performance camshaft and a windage tray", where the 330 hp engine lists a "standard camshaft" and no mention of a windage tray. I also thought the 383 HP engine got a different intake manifold from the 440 HP engine?
MikeR
330 hp, 383 specs:
Re: '69 roadrunner w/AC - engine color? [Re: A12] #152200
11/18/08 09:22 PM
11/18/08 09:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
the 335 hp, 383 specs:
Re: '69 roadrunner w/AC - engine color? [Re: A12] #152201
11/18/08 11:00 PM
11/18/08 11:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Intake manifolds are not interchangeable between "B" engine (383) & "RB" engine (440)
All '69 383 4bbl intake manifolds are the same.
Re: '69 roadrunner w/AC - engine color? [Re: A12] #152202
11/18/08 11:23 PM
11/18/08 11:23 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I wonder if you could get the chrome exhaust tips with the 330 horse 383?
Re: '69 roadrunner w/AC - engine color? [Re: RoadRunnerJD] #152203
11/19/08 12:42 AM
11/19/08 12:42 AM
Va. Beach, Va
Va. Beach, Va
My Bee came with turned down tips stock. I know in 70 they were an option not sure about 69. I do know mine has them now..original or not
Re: '69 roadrunner w/AC - engine color? [Re: 6bblgt] #152204
11/19/08 01:16 AM
11/19/08 01:16 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Dan, I'm not sure what you mean by 'technically', but a 383 four speed 500 would have the HP assembly.
I agree you'd need tag or BS proof for an A/C car to have the HP assembly.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '69 roadrunner w/AC - engine color? [Re: rrunner] #152205
11/19/08 01:18 AM
11/19/08 01:18 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
No.
Seeking:
Re: '69 roadrunner w/AC - engine color? [Re: 69CoronetRT] #152206
11/19/08 01:26 AM
11/19/08 01:26 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
No.
What is the 900 383 cid then ?
Re: '69 roadrunner w/AC - engine color? [Re: stateline] #152207
11/19/08 01:36 AM
11/19/08 01:36 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
No.
I've seen 900 used for a late built Charger automatic no air.
Seeking:
Re: '69 roadrunner w/AC - engine color? [Re: 69CoronetRT] #152208
11/19/08 01:48 AM
11/19/08 01:48 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
No.
925 = 383 4bbl, 4-speed, heater (RM/WM)
926 = 383 4bbl, automatic, heater (RM/WM)
Is this correct?
Re: '69 roadrunner w/AC - engine color? [Re: A12] #152209
11/19/08 02:18 AM
11/19/08 02:18 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
No.
Is this correct?
Yes but you'll find 925 in non RRs and SBs (e.g. WP, RP, XP)
Seeking:
Re: '69 roadrunner w/AC - engine color? [Re: 69CoronetRT] #152210
11/19/08 10:00 AM
11/19/08 10:00 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Doug, I know turquoise is correct but I cant put a motor that color in my 500 383/4bbl/ac vert, The car is not stock so orange is what Im going with, 95% of the people wont know anyways
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: '69 roadrunner w/AC - engine color? [Re: RoadRunnerJD] #152211
11/19/08 10:01 AM
11/19/08 10:01 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I didnt see it as an option for my H code 500 but I could be wrong, Im putting some on anyways
