Pin inside 440 Intake Manifold #1522215
10/23/13 07:13 PM
10/23/13 07:13 PM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Hey Guys
Just wondering before I install my ThermoQuad on the factory 440 intake on my 1978 Power Wagon if I can or should remove the pin down inside the intake. What does it do?
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Pin inside 440 Intake Manifold [Re: ChrgrCuda] #1522216
10/23/13 09:08 PM
10/23/13 09:08 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Pics
I am truckless..
Re: Pin inside 440 Intake Manifold [Re: ChrgrCuda] #1522217
10/23/13 09:15 PM
10/23/13 09:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That is a floor jet for the egr system.
Re: Pin inside 440 Intake Manifold [Re: NITROUSN] #1522218
10/23/13 09:50 PM
10/23/13 09:50 PM
Texas, USA
Texas, USA
Can or should I remove it? Looks like a major deterrent for any kind of performance.
Re: Pin inside 440 Intake Manifold [Re: ChrgrCuda] #1522219
10/23/13 10:03 PM
10/23/13 10:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That intake is a smogger non performance intake. So there most likely be no gains either way. There used to be a factory plug for the intake. Does the jet have an outside hex for a socket for removal? If so you could pull it, cut it short and weld the hole closed and re install it.
Re: Pin inside 440 Intake Manifold [Re: NITROUSN] #1522220
10/23/13 10:24 PM
10/23/13 10:24 PM
Texas, USA
Texas, USA
Thanks for all of the info Nitrous. I will look into it when I get home tomorrow. If no performance is to be gained I'll probably leave it alone.
