03 300m computer codes ? What they are? #1522181
10/23/13 05:37 PM
10/23/13 05:37 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Still haven't gotten wife's car figured out but check engine light just came on. She stopped at Advance Auto to get it read. Here is what they gave her.
PO 562 system voltage low(she's going back to gèt battery load tested)
PO 700 transmission light
PO 304 cylinder 4 misfire.
So if the battery is weak which I'm thinking it is would it cause the other codes?
Contact Me about AMD Prices
Re: 03 300m computer codes ? What they are? [Re: hotairballoonpilot] #1522182
10/23/13 06:43 PM
10/23/13 06:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
#4 misfire could be bad plug, bad wire or bad coil. For the trans light that is a generic code and you will have to have a trans shop or someone with a scanner capable of reading trans codes to scan for that. A basic obd2 scanner won't go that far. When did you last do a tune up on it?
