Re: 1971 340 Owners - What's Wrong With These Pictures?
[Re: 70gtx440dana]
#1521820
10/23/13 11:27 AM
10/23/13 11:27 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Yes sir!
This is the third 1971 340 car I've documented with an orange engine installed way past the orange to blue color changeover (late March/early April or so). This cars SPD is May 21, 1971, yet the engines assembly date is WAY earlier (3373 10,000 day calendar date = Thursday October 22, 1970) and has an original VIN# sequence stamping that matches the cars VIN and fender tag. The other two cars were Demons and were Hamtramck plant cars, this one is the first B-body and the first Los Angeles car I've seen this way.
Typically issues like this can be explained by some sort of quality control measure that set a component (in this case an engine) aside from the production line for repair or re-work. The engine was likely removed from production at an earlier date. It was then re-worked and finally re-introduced back into production some time later. This type of event was not so uncommon then and still happens today.
Mine has the sideways X with the Maltese cross and a A4 after the numbers. not sure if something is .010 under i think the Maltese cross is -.010 mains, and an A4 might have meant an oversize bore but not sure.
[Re: ademon]
#1521822
10/23/13 04:57 PM
10/23/13 04:57 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
Yep they pushed a rack or two of orange 340 engines into a corner and forgot about them till the first week of April, my demon is a SPD of April 2nd with a engine build date of I think November something 1970. You probably have the details of my engine better than I do Scott!
exactly correct!
[Re: 1972CudaV21]
#1521826
10/24/13 10:01 AM
10/24/13 10:01 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Is there any way to re-stamp those numbers just below the left head? Nothing sinister, just the fact that the numbers can barely be read on my block. My VIN is fine...
No,(good way to ruin your blocks authenticity having been altered though)..........and barely readable is plenty good enough.
[Re: ScottSmith_Harms]
#1521827
10/24/13 03:51 PM
10/24/13 03:51 PM
Posts: 3,131 across the river from Portland...
472 R/T SE
Yeah, no doubt. All it would be doing is adding an element of suspicion.
[Re: 472 R/T SE]
#1521828
10/26/13 07:30 PM
10/26/13 07:30 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Hmmm...you make a good point. Maybe I can just do the best that I can to preserve the original numbers.
