Re: '69 roadrunner w/AC - engine color?
[Re: DPelletier]
#152192
11/18/08 12:22 AM
11/18/08 12:22 AM
Posts: 20,765 A collage of whims
topside
A collage of whims
Owned 2 original, #s, St.Louis '69 RRs with A/C. Turquoise 330-horse, RR pie tin, dual snorkels. Every original #s '69 RR with A/C, regardless of trans, that I researched at the time had the turquoise 330 motor, not the orange 335. Every non-A/C '69 383 I've seen, and I mean hundreds, was the orange 335. The small unsilenced air cleaner was a orange/335 setup, and the dual snorkel was for turquoise/330 motors. Carter carbs on every original '69 RR 383 I've seen, though different model #s depending on trans, A/C, Calif & high altitude (Denver for example). Calif & high-altitude carbs had one central mixture screw. The RR pie tin fits both air cleaners, as did the other pie tins. Magnum was the Dodge marketing name, as previously stated, and would not be found on a Plymouth except by error. For what it's worth, I've found that some '68s & '69s ran stronger than others, and not necessarily related to the 330/335 rating. For example, my A/C car was stronger than one of my non-A/C cars, and except for the A/C, seats & color they were basically identical. The 335 car "should" have been quicker, but wasn't. My St.Louis-built '68 was quicker & more responsive than my L.A.-built '68 car, too.
[Re: SomeCarGuy]
#152194
11/18/08 03:33 PM
11/18/08 03:33 PM
Posts: 6,679 Va. Beach, Va
69superbee383
Va. Beach, Va
I have a 69 bee with AC and the 899 engine. The engine is turquoise and it came with a 383 four barrel pie tin vs. the 383 magnum one. The block is not stamped HP. Also the carb was a Holley and not a Carter from the factory. It also has a different transmission as well at least by part number to the non ac cars.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: rrunner]
#152198
11/18/08 08:46 PM
11/18/08 08:46 PM
69superbee383
Va. Beach, Va
Well I can tell you my 899 engine is not. Numbers matching and I bought the car from the original owner. Engine assy date is stamped 12 2
[Re: A12]
#152201
11/18/08 11:00 PM
11/18/08 11:00 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
I also thought the 383 HP engine got a different intake manifold from the 440 HP engine?
Intake manifolds are not interchangeable between "B" engine (383) & "RB" engine (440) All '69 383 4bbl intake manifolds are the same.
[Re: RoadRunnerJD]
#152203
11/19/08 12:42 AM
11/19/08 12:42 AM
69superbee383
Va. Beach, Va
My Bee came with turned down tips stock. I know in 70 they were an option not sure about 69. I do know mine has them now..original or not
[Re: 6bblgt]
#152204
11/19/08 01:16 AM
11/19/08 01:16 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Technically the 383HP wasn't available in the '69 Coronet 500.
... so besides a "HP" stamp, what evidence do you have to support that claim?
B'cast sheet and or Lynch Rd. fender tag numbers?
Dan, I'm not sure what you mean by 'technically', but a 383 four speed 500 would have the HP assembly.
I agree you'd need tag or BS proof for an A/C car to have the HP assembly.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#152208
11/19/08 01:48 AM
11/19/08 01:48 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
So is the 899 383 stamped HP or not?
No.
What is the 900 383 cid then ?
I've seen 900 used for a late built Charger automatic no air.
925 = 383 4bbl, 4-speed, heater (RM/WM)
926 = 383 4bbl, automatic, heater (RM/WM)
Is this correct?
[Re: A12]
#152209
11/19/08 02:18 AM
11/19/08 02:18 AM
69CoronetRT
Harlan, Iowa
No.
Is this correct?
Yes but you'll find 925 in non RRs and SBs (e.g. WP, RP, XP)
Seeking:
[Re: 69CoronetRT]
#152210
11/19/08 10:00 AM
11/19/08 10:00 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Doug, I know turquoise is correct but I cant put a motor that color in my 500 383/4bbl/ac vert, The car is not stock so orange is what Im going with, 95% of the people wont know anyways
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: RoadRunnerJD]
#152211
11/19/08 10:01 AM
11/19/08 10:01 AM
AZ_A12_BEE
Dreaming of the 808
I wonder if you could get the chrome exhaust tips with the 330 horse 383?
I didnt see it as an option for my H code 500 but I could be wrong, Im putting some on anyways
37 Plymouth PU
