Re: Just a thanks to Brian Smith for getting it "all"
[Re: 408strokerdart]
#1521670
10/23/13 08:45 PM
10/23/13 08:45 PM
Posts: 1,784 PA
W5DART66
PA
So, I ask this to Brett.....Is there a chance at 5.0's with a max effort N/A SB build based around your current "big" port at 417 CID and still be a reliable bracket car? And I'm trimming weight again this winter....should be around 2740 race weight.
I can't Promise anything but I would work my a$$ off for you.
I can send big port to HRE and get manifold started :-)
1.00" of cam 9500 RPM springs 30-50 passes
I think we can make 100-150 more HP
#1521672
10/23/13 08:57 PM
10/23/13 08:57 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Great job....the car is flying.
"Max effort" and reliable bracket car are usually not found in the same sentence. Although if you get that car down in the 2700# range, a truely max effort W8 with a sheet, 2 x 4 and all the other ingredients will go well past 1000hp.
Might need a Proflite to run in the 5.0 range though....that is fast for an N/A straight headed smallblock at that weight, but I think Paul Ricci has run 8ohs at E-Town around 2800#.
I'm sure there are quicker out there, but parts to parts I think we are doing very well. These are 17 year old heads with a modern port and small cam, single 4bbl, small cast intake (and not the "good" one).
You are right Jim, reliable and max effort are different things which is why I'm torn over putting a big wedge in this or making this combo quicker at the cost of reliability.
Very impressive combination indeed.
There is something to say for a straight headed smallblock MOPAR with a discontinued cylinder head kicking butt. Drop some weight, puff the engine up and let err' rip.
[Re: W5DART66]
#1521673
10/23/13 09:00 PM
10/23/13 09:00 PM
jim sciortino
Trumbull,CT.
This.....
[Re: justinp61]
#1521676
10/23/13 10:08 PM
10/23/13 10:08 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Impressive to post those numbers with a glide. Most have some good torque numbers.
[Re: Leon441]
#1521677
10/24/13 12:00 AM
10/24/13 12:00 AM
Posts: 3,456 Out West
408strokerdart
Out West
Hauling the mail for sure.
I would have to do some digging but those numbers as good or better that Tim Davis was doing back in NSCA Hot street in 05'. Tim had the better intake. Set the NHRA record in B super modified. He also did a ton of developing and testing.
I was very displeased with my NA numbers 5.69 with a 2,950 race weight and a glide. Felt there was better numbers in the car like 5.40's. The 60 ft with the glide just would not cooperate.
What transmission are you running Brian? I would assume a Torqflite. Inquiring minds want to know.
Leon
It has an ATI cased glide with an ATI 8" converter. It goes just a tick under 6K RPM.....wish it was a tad looser. Just didn't want to send it in as the car is doing as much or more than expected.
I'm sure it would be quicker with a 3 speed, but consistency has been stellar and predictable.
[Re: W5DART66]
#1521678
10/24/13 12:06 AM
10/24/13 12:06 AM
408strokerdart
Out West
Maybe we need for sale add in race parts for killer w8 top end package to offset upgrade deal.
I would have to. I still have a non income producing home I can't seem to sell....going on 2 years now. It's really cutting into my racing budget.
[Re: W5DART66]
#1521679
10/24/13 12:09 AM
10/24/13 12:09 AM
408strokerdart
Out West
Add the 3 speed transmission and it would sound like a Comp Eliminator car then.
[Re: BigDog68Dart]
#1521683
10/24/13 05:09 PM
10/24/13 05:09 PM
Leon441
Lynchburg, VA
My tranny guy is trying to get me to go ATI. I think there may be something to that. I borrowed an 8" converter that 60 ft'd much better than the custom pieces I had. Always felt that if I had a smaller tire and could control wheelspeed I could actually 60 ft better. My 32X14.5 tires are much slower than the 31X10.5 tires.
Your 60 ft is exactly .1 better than my best with the W8 motor I had. That alone would have brought my ET into the 5.5's. Knew where I was coming up short just did not know what to do about it. LOL. My dyno numbers started at 6,900. We thought peak torque was at 7,100 going by the dyno sheet. Where is your peak torque at if you don't mind telling? Your MPH is proving the power you are making.
Leon
[Re: Leon441]
#1521684
10/24/13 07:55 PM
10/24/13 07:55 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
Super results there Brian Not only quick but a very nice car overall!! If you ever decide to go the mega big block route, I know a certain little blue Dart that ole small block will drop in Take care!!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
[Re: G-Money1320]
#1521685
10/24/13 10:11 PM
10/24/13 10:11 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Brian
How much do you think the car would pickup with a toilet and Alky? I ask because I know a guy with smallblock who saw about 2.5 tenths difference going from race gas to the injected Alky swap. This was a car that went mid 9's before the swap, not as fast as yours but a very nice gain none the less. 450ish inch Indy head motor, btw
[Re: B3422W5]
#1521686
10/24/13 10:23 PM
10/24/13 10:23 PM
jim sciortino
Trumbull,CT.
Brian
That's a good gain.....around 60hp, probably.
[Re: jim sciortino]
#1521687
10/24/13 10:39 PM
10/24/13 10:39 PM
B3422W5
Portage,michigan
Brian
That's a good gain.....around 60hp, probably. [/
Yep... For a short while he considered going back to gas, and I loaned him the 1100 dominator off my 422 W5 motor. He used it one weekend and lost 3 tenths with my carb and swapped back again.That was the end of that experiment quickly. So basically going from the carb he used to Alky and toilet he gained 2.5 tenths. Going back to gas using my carb( which obviously was off a little he lost 3 tenths.... So my. carb was half a tenth worse than the carb he had originally had on his car. He did this because the car became Inconsistant on the starting line spinning sometimes because of the extra torque with the Alky over gas. He ultimately sorted the chassis out. Car runs 9.20 now with the small block Indy heads and Alky. Think it went 9.22 at Norwalk, if not a hair better
