70 Cuda rear window questions #1521605
10/22/13 05:36 PM
10/22/13 05:36 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
Are the rear window moldings on a 70 Cuda screwed on, or were there welded studs on the window channel for the clips to snap in?
There are 2 metal "spacers" in the bottom of the rear window channel for the glass to sit on so that the glass is properly set into place. Are those spacers available to buy (aftermarket or dealer)? Also, I need to see pictures of those spacers.
Thank you.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 70 Cuda rear window questions [Re: 11secaarcuda] #1521606
10/22/13 09:03 PM
10/22/13 09:03 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
The edge molding is held on with I think two clips, that push into holes on the top of the quarter. Im not sure what u mean on the down stops the window follows the track to the bottom.
Re: 70 Cuda rear window questions [Re: magiccuda] #1521607
10/22/13 09:31 PM
10/22/13 09:31 PM
SE PA
Born2Run Offline
Born2Run  Offline
SE PA
These might be the spacers you are referring to ...
http://www.hooverautoparts.com/products/Clips%20and%20Fasteners/13714.php
Re: 70 Cuda rear window questions [Re: Born2Run] #1521608
10/22/13 10:37 PM
10/22/13 10:37 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
The clips that hold the moulding on are screwed on for '70. I believe the "studs" to hold the clips in place started in '71.
Re: 70 Cuda rear window questions [Re: Born2Run] #1521609
10/22/13 11:37 PM
10/22/13 11:37 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I would like to see those clips installed myself.
Careful, your character's showing!
Re: 70 Cuda rear window questions [Re: Born2Run] #1521610
10/23/13 09:04 AM
10/23/13 09:04 AM
WASHINGTON, PA
WASHINGTON, PA
Thanks, that looks like them.
2011 Hemi Durango
Re: 70 Cuda rear window questions [Re: 11secaarcuda] #1521611
10/23/13 09:26 PM
10/23/13 09:26 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
my mistake I thought he was asking about the quarter glass. Yes rear window molding held on with screw on clips.
Re: 70 Cuda rear window questions [Re: magiccuda] #1521612
10/23/13 09:53 PM
10/23/13 09:53 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Those are not clips that hold the molding on those are simply to help line up the glass when it is installed and are completely unnecessary.
Re: 70 Cuda rear window questions [Re: magiccuda] #1521613
10/23/13 11:51 PM
10/23/13 11:51 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Sure are handy if you're using urethane. Not so much with the butyl though as the butyl kit usually comes with setting blocks.
