Reproduction oil pressure sender
#1521411
10/22/13 12:07 PM
10/22/13 12:07 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
I bought a reproduction oil pressure sender p/n 2495222 (80 psi)from Bill Rolik for my 440 Superbird, but noticed the dash gauge was reading lower than the actual oil pressure (as measured with a mechanical gauge) I took it off to check the calibration and found it to be way off
At 0 psi, the sender was open circuit (it should have been ~74 ohms) The sender remained open circuit until 14 psi. At 80 psi, the resistance was 15.3 ohms instead of the the expected ~10 ohms. ( I had my gauges restored and calibrated by Redline and had an electronic voltage regulator installed) Bill was kind enough to send me another one, but it turned out to be the same. Instead of returning them for a refund (which Bill offered to do) , I decided to cut it open. The following are some photos of the guts as compared to a stock Mopar unit. It is a totally different design and the resitance winding is not designed correctly to interface with the Mopar gauges. This seems to be similar to the repro fuel tank level senders that are not wound correctly. Looks like everyone is using the same company in China to make these repro's. This is a photo of the guts of the repro. The brass wiper is not making any contact with the windings at 0 psi.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
Re: Reproduction oil pressure sender
[Re: RealWing]
#1521412
10/22/13 12:08 PM
10/22/13 12:08 PM
RealWing
Ontario, Canada
This is a photo at 80 psi.
[Re: RealWing]
#1521413
10/22/13 12:09 PM
10/22/13 12:09 PM
RealWing
Ontario, Canada
This is the original Mopar unit at 0 psi.
[Re: RealWing]
#1521414
10/22/13 12:09 PM
10/22/13 12:09 PM
RealWing
Ontario, Canada
This is the original at 80 psi
