So now i have to give a call to DR.Diff for a set of 35 splines. more Dough to Blow... but my rear should be solid.. so ill probably give them a call tomorrow.
As for now waiting on that and my raptor liner.. thought I'd do some interior pieces.. I'm going to be remaking Door panels. so heres what i got so far...
Bought some of this 1/8th board from home depot...stuff is cheap for the amount you get...
![](http://i41.tinypic.com/2njwym9.jpg)
Cut the board out to size of the door panel (I traced out mine from my originals that came with the car) or make a template from cardboard.
![](http://i43.tinypic.com/34xqtkj.jpg)
Don't forget to cut a hole out for the window crank!!
![](http://i41.tinypic.com/2sajmg5.jpg)
I used about 1/4 inch light foam for some padding effect.. i know they don't come with it from factory... but i like it with it
![](/ubbthreads/images/graemlins/biggrin.gif)
![](http://i42.tinypic.com/156wjmh.jpg)
Sand the edges with some low grit to smooth out from it edginess
![](http://i42.tinypic.com/211whkx.jpg)
Lay the board on top of the cut piece to make sure you have enough!
![](http://i42.tinypic.com/11ugp5i.jpg)
Use Spray adhesive to bond them together NOT pressing hard...but light to make contact with the board..(Glue will push through since its a thin foam) if your going to use a spray adhesive for interior pieces id strongly suggest you use TACK spray.... such as..But you can also use 3M 300 hold.. and what i did is i drew an outline around the cutout while it sits on the foam to know where you spray (i sprayed foam then laid the cutout on top of the foam..
![](http://i42.tinypic.com/e8pq9s.jpg)
![](http://i39.tinypic.com/5otpax.jpg)
I'm going with black on black interior, just because i like it... and it is hard to dirty black.. here is my black vinyl i picked out..
Same process laying it on the vinyl..
![](http://i44.tinypic.com/2pz0ls3.jpg)
Almost Done!! going to wait to tack the backside till i get my Air stapler. it could be glued with the same tack glue... but i don't want it to risk pealing up. so for now I'm left with this finished product till i get it.. Came out good so far though. (Oh, make sure you steam off the wrinkles BEFORE application, or else you risk reactivating the glue..)
![](http://i44.tinypic.com/b6605j.jpg)
Finished product coming soon!!!
