donovan gear drive w/distributor? #1520631
10/20/13 06:20 PM
10/20/13 06:20 PM
geezer acres rest home
dakotawilly Offline OP
anyone know of a kit or manufacturer making a kit to utilize a front drive distributor either belt or direct off a gear drive? it appears to be possible using a fuel pump drive cover.if nothin is available i may have to try this on my own....
SFI 25.5 depends,no leak,even at 213 mph....
Re: donovan gear drive w/distributor? [Re: dakotawilly] #1520632
10/20/13 06:37 PM
10/20/13 06:37 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use a rcd mag drive on my rcd gear drive. Try RCD and RBS superchargers
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: donovan gear drive w/distributor? [Re: bigtimeauto] #1520633
10/21/13 11:18 AM
10/21/13 11:18 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Normally when I see that done they are using a Jesel belt drive.
2011 Drag Pak Challenger
Re: donovan gear drive w/distributor? [Re: rickseeman] #1520634
10/21/13 11:31 AM
10/21/13 11:31 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I have never seen one other than for a belt drive but I don't see why you couldn't do it the way you mentioned.
Re: donovan gear drive w/distributor? [Re: mac56] #1520635
10/21/13 11:51 AM
10/21/13 11:51 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
