Re: 1970 Road Runner horn issue
[Re: mikemee1331]
#1520577
10/20/13 06:14 PM
10/20/13 06:14 PM
Posts: 11 Indiana
mowch70
Indiana
Wiring is original and in good shape. I've had the steering wheel off to replace the ignition switch and everything looked fine. I didn't think about the spot where the steering wheel "parks". I'll have to stop the car with wheels turned a little bit, and see if that changes things. I think it's the relay, but couldn't think of anything else. Thanks.
[Re: MOPARMIKE69]
#1520579
10/21/13 10:52 AM
10/21/13 10:52 AM
RapidRobert
What mike said, grab your meter & get after it when it ain't working to find the part time open. As you know wires in a circuit lose continuity at the terminals/ends & I'd check all of em & seperate the pull apart connector under the steering colume & ohm it to see if the problem is under the steering wheel. I would think that the relay is still on the firewall but you'd easily spot it if it is
[Re: mikemee1331]
#1520582
11/05/13 01:24 PM
11/05/13 01:24 PM
Posts: 2,683 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Will a RR horn work without a relay? I want to put one on something that just a has a 12 volt wire going to it for the beep beep sound.
2011 Drag Pak Challenger
[Re: rickseeman]
#1520583
11/05/13 01:58 PM
11/05/13 01:58 PM
RapidRobert
If you used an add on momentary contact switch & wires of adequate gauge it'd work. The steering wheel contact, grounds the wire so there would not be a way for the steering wheel contact to open/close a hot 12V power in feed wire which the add on momentary contact switch would do. Not sure if that is what you are asking
[Re: RapidRobert]
#1520584
11/06/13 02:16 AM
11/06/13 02:16 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
for it to go beep beep you need to push the button twice...LOL
I am truckless..
