PPG Delstar paint question #1520455
10/20/13 12:11 PM
10/20/13 12:11 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
I have some of Frank Badelson's engine paint to spray. Its a acrylic enamel paint. I have two questions.
Q1- Tech sheet specifies usnig the DTR reducers per the temperature, I have some DT870 on hand can I substitute the two. The DTR reducers are Acrylic Enamel reducers but the can of DT does not say for use with this type of paint.
Q2- The mix ratio is color 8 - reducer 3 and hardener 1. The supplier of the paint said do not use the hardener it will be too shiny. So question is how do I modify the mix ratio. Do I just substitute the hardner with reducer?
Thanks for the help, I am really new at this painting stuff
Re: PPG Delstar paint question [Re: gygeneral] #1520456
10/20/13 03:23 PM
10/20/13 03:23 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
In the past I've always used the DTR reducer, but suspect the the DT870 would work. As far as modifying your ratio, no need to substitute for lack of hardener. Just go 8-3 and spray it.
Re: PPG Delstar paint question [Re: BarrsRestoration] #1520457
10/20/13 04:13 PM
10/20/13 04:13 PM
west australia
8trackbee Offline
8trackbee  Offline
west australia
no hardner in acrylic enamel, can you do that? won't the paint stay soft...
Re: PPG Delstar paint question [Re: 8trackbee] #1520458
10/20/13 04:16 PM
10/20/13 04:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I just did some touchup with Delstar and no hardener, it will dry but takes a little longer.
Re: PPG Delstar paint question [Re: 8trackbee] #1520459
10/20/13 04:20 PM
10/20/13 04:20 PM
Kirkland, Washington
Pacnorthcuda Offline
You can, but the result is not nearly as durable as catalyzed paint. The catalyst actually "cross links" the molecules. That means its literally a different finish, and is far more durable. Harder, more chemically resistant etc.
Re: PPG Delstar paint question [Re: Pacnorthcuda] #1520460
10/20/13 09:17 PM
10/20/13 09:17 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Do NOT use DT reducer, it is for urethanes. Chances are you will ruin your paint in a quick and fast hurry. You need the appropriate enamel reducer.
As noted, it will air dry with time. The hardener makes it much faster but is not necessary.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: PPG Delstar paint question [Re: herkamer] #1520461
10/20/13 11:23 PM
10/20/13 11:23 PM
Ont, Canada
Ont, Canada
That's what I have found from google searches but I wasn't sure if it was just a PPG sales gimmick. I will call tomorrow and see if I can get the appropriate reducer. I would imagine I can use anyones reducer as long as its for acrylic enamel, right.
Re: PPG Delstar paint question [Re: gygeneral] #1520462
10/21/13 10:09 AM
10/21/13 10:09 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Correct, I believe any acrylic enamel reducer will work fine. I've used DTR in Dupont just fine. As long as the system is the same, you shouldn't have any problems. Always try to mix a little first to see if it has any weird reactions. I've had paint curdle like bad milk because of old or wrong components.
Matt
69 Dart Swinger 340
and even more
Re: PPG Delstar paint question [Re: herkamer] #1520463
10/21/13 02:36 PM
10/21/13 02:36 PM
Ont, Canada
Ont, Canada
This morning I had to go to the USA to buy the reducer. Nowhere here in Canada sells this stuff. It was banned a few years ago.
Next thing is the mix formula. The mix ratio is color 8, reducer 3, hardener 1. Since I'm not putting the hardener in how do I modify the mix. The store told me color 4 and reducer 1. That is a lot less reducer than the mix with the hardener. Does this make sense???
Re: PPG Delstar paint question [Re: gygeneral] #1520464
10/21/13 02:43 PM
10/21/13 02:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Don't change the ratio, just don't add the hardener, like said above.
Re: PPG Delstar paint question [Re: Challenger 1] #1520465
10/22/13 09:45 AM
10/22/13 09:45 AM
Ont, Canada
Ont, Canada
Thanks, I will try that.
Re: PPG Delstar paint question [Re: gygeneral] #1520466
10/23/13 11:28 AM
10/23/13 11:28 AM
pa.
dan9 Offline
dan9  Offline
pa.
We used to use lacquer thinner also to thin acrylic enamel , it works.
