Priming big block #1520372
10/20/13 11:14 AM
10/20/13 11:14 AM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
While priming and turning over engine slowly I notice a lot of oil coming from between shaft and head and nothing from rockers. I do have the shafts facing down. Is this normal? It has a small solid roller and crane aluminum rockers. I did not restrict oil to the top end.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Priming big block [Re: EV2CUDA] #1520373
10/20/13 01:02 PM
10/20/13 01:02 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Are you talking its leaking where the shafts fit down in the groves of the head? No, that isn't normal. Do you have shims between the shaft and the head? If its leaking there, the oil cant go into the shaft and out of the rocker arms. Must be a pretty big leak. Check to make sure the shaft is down in the groove and the washers or shims you are using isnt holding the shaft out of the grove.
Re: Priming big block [Re: Dodgeguy101] #1520374
10/20/13 03:41 PM
10/20/13 03:41 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Upon further inspection, being used shafts, it looks like they are out of round. I don't have shims under them.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: Priming big block [Re: EV2CUDA] #1520375
10/20/13 10:15 PM
10/20/13 10:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's why they only get torqued to 25 ft/lbs !!!
