New fuel pump wiring 1975 Trailduster #1519966
10/19/13 01:32 PM
10/19/13 01:32 PM
Ca
MikeT Offline OP
MikeT  Offline OP
Ca
Looking for anyone thoughts on the way I plan on wiring a new fuel pump. Mostly not sure of the starter relay wiring. See diagram.
Re: New fuel pump wiring 1975 Trailduster [Re: MikeT] #1519967
10/19/13 02:11 PM
10/19/13 02:11 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
It looks good to me. Our truck has the same setup but I skipped the start circuit. When you fill up the bowls in the key "on" position that should be more than enough for < or = to 15 seconds of cranking. This way you are not running the fuel pump on low voltage while cranking and possible damaging it.
Either way it looks great. I'd hire you to do my truck in a second.
