case only difference between BB vs SB 727? #1519924
10/19/13 12:06 PM
10/19/13 12:06 PM
CheddarHead till October
weedlayer Offline OP
My new 727 has some bolt holes off. Thinking my builder built a BB instead of a SB. Have not had a chance to check things real close but suspect that is the problem. Easiest fix might be to just change the internals to my other case if I can?
Re: case only difference between BB vs SB 727? [Re: weedlayer] #1519925
10/19/13 12:09 PM
10/19/13 12:09 PM
Torrance, Ca
Fig Offline
Fig  Offline
Torrance, Ca
I'm not a 727 expert, but I cant think of one part that is not interchangeable. I lifted this off of another web site if you want to verify big or small block:
It's EASY to tell them apart if they're not attached to an engine. Course, I take for granted you can tell a 727 apart from a 904 from the pan. However, big and small block 727s are simple to distunguish. The small block version only has two torque converter dust cover retaining bolt holes across the bottom of the bell housing. The big block version has four. Of course, the bolt patterns are different, but the dust cover bolt holes are an easy fast way to tell.
____________________
Read more: http://forums.moparmusclemagazine.com/70.../#ixzz2iBMbvBn8
1937 Plymouth R/S Coupe
440/727
Re: case only difference between BB vs SB 727? [Re: weedlayer] #1519926
10/19/13 01:10 PM
10/19/13 01:10 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Only difference is the case. All parts will swap.
Re: case only difference between BB vs SB 727? [Re: dizuster] #1519927
10/19/13 01:36 PM
10/19/13 01:36 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Quickest way to tell is the starter position...
If you are looking at the converter opening with the input shaft facing you, the BB has a starter position around 3 o clock...SB is lower...like 4:30 or 5 o clock...
MB
Re: case only difference between BB vs SB 727? [Re: HPMike] #1519928
10/19/13 03:09 PM
10/19/13 03:09 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Also, the mounting bolts for the struts on the SB case require a large diameter hole at 8 and 4 o'clock
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: case only difference between BB vs SB 727? [Re: Polarapete] #1519929
10/19/13 03:15 PM
10/19/13 03:15 PM
GEORGIA
barracuda7199 Offline
GEORGIA
i always look at the dowel pin holes. small block is straight across from each other. big block the starter side dowel pin hole is higher than the other side.
Re: case only difference between BB vs SB 727? [Re: barracuda7199] #1519930
10/19/13 07:43 PM
10/19/13 07:43 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ya beat me to it. Also you can measure the distance between dowels openings on the case and measure the dowels in the block.
Re: case only difference between BB vs SB 727? [Re: weedlayer] #1519931
10/20/13 08:14 AM
10/20/13 08:14 AM
central pa
darted1 Offline
darted1  Offline
central pa
If I remember correctly small block uses a bolt at the top center of bell housing to attach to the motor. the big block doesn't their top bolt holes are at like 11 0clock and 1 oclock so there shouldn't no bolt hole at the top of the big block bell housing.
ED M
Re: case only difference between BB vs SB 727? [Re: darted1] #1519932
10/20/13 09:17 AM
10/20/13 09:17 AM
SE VA
hemibee69 Offline
hemibee69  Offline
SE VA
That is how I differentiate small to big block bellhousing. If it has a bolt at the top in the center it is a small block. Easy and quick to see.
JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly)
1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph
1970 Challenger SE 383 4 bbl A/C PB PS Leather
1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: case only difference between BB vs SB 727? [Re: hemibee69] #1519933
10/20/13 03:35 PM
10/20/13 03:35 PM
it's a BB case. I'll just move everything to my SB case. Thanks for the info.
Guess I should have looked before I drug it under the car and tried to bolt it up.
Re: case only difference between BB vs SB 727? [Re: hemibee69] #1519934
10/20/13 03:54 PM
10/20/13 03:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
JiK
No hole at top center.
