Re: Voltage regulator kick in and out
[Re: mopwrd340]
#1519738
10/21/13 01:36 PM
10/21/13 01:36 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
With it jumping around like that, it sounds like the components are ok, but you may have a corroded wife somewhere making an intermittent connection.
Check the integrity of the wires
**Photobucket sucks**
[Re: 70Cuda383]
#1519739
10/21/13 07:54 PM
10/21/13 07:54 PM
Posts: 7,664 IN
ahy
IN
The special triangle shaped connector that hooks to the VR is a common point of failure. The connectors get dirty and hot then open up. Changing the regulator may have temporarily gotten a connection.
If the connector looks bad, the help section at the AP store usually has replacement with pig tail that can be spliced into the harness.
PS: Measuring voltage at idle is not a reliable check of the system. Alternator output is low so depending on lots of factors (loads, pulley size, idle speed, battery ect.) voltage may be quite low. Best to measure at around 2000 RPM with a charged battery so you are really seeing performance of the charging system.
[Re: mopwrd340]
#1519742
10/22/13 08:41 AM
10/22/13 08:41 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Check the amp gauge.Everyone that I owned the gauge was pretty much toast.I eliminated them and installed a volt gauge.Rocky
Chrysler Firepower
