Re: what compression ratio
[Re: dOc …]
#151933
11/16/08 09:34 PM
11/16/08 09:34 PM
Posts: 5,167 CT
GTX MATT
CT
The other most important factor is probably cam specs. 10.5:1 is doable, for myself though with a 440 I dont think id try over 10:1 unless I was running a pretty agressive cam just because Id be annoyed if I put an engine together and then had to keep the timing retarded more than I wanted to run on the pump salad oil we get nowadays. Quench is important too, with 915s youd have a better shot than open chambered 906s.
10.5:1 is pretty impressive, youre running iron heads on that? How much did you have to retard your timing? If its working more power to you!
Id say most guys build for around 9.5:1 with a pump gas 440 though if they have iron heads. Once you get up that high the difference between 9.5 and 10.5 wont be much ponies or torque unless youve got a cam that needs the extra compression. You just have to ask yourself, is something like 8 hp worth the aggrivation and/or the expense of octane booster or blending gas? You might even loose power from having to retard the timing with 10.5:1 vs the timing you should have with 9.5:1.
[Re: GTX MATT]
#151934
11/16/08 09:57 PM
11/16/08 09:57 PM
RapidRobert
906's wont give you quench because of the open chambers & that's going to limit you the most.
[Re: Hughes]
#151938
11/18/08 12:33 PM
11/18/08 12:33 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Kevin's right. Except I run a bit higher numbers than Hughes with success. (at sea level...) With care, 185psi using open iron heads will not detonate on 93octane with 10%ethanol. But your tuning must be spot on.
[Re: moper]
#151939
11/18/08 11:34 PM
11/18/08 11:34 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Cam is the big variable for sure. So is weight, gear and so on.... My 440 doesn't ping at 10.6:1 with a 242@50 racer brown cam 3400 stall, 373 gears etc In contrast My old 68 newport would ping on 2-3 shift with a stocker cam, and around 8.5:1 comp. If its' built mild, the compression will make it ping. Another factor to consider if you are building from scratch,is why build in a potential problem with too much compression? Most engine builders agree, one full point of compression will only gain you 3-4% max horse power in a given combo ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: tpabayflyer]
#151945
11/20/08 11:07 AM
11/20/08 11:07 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I agree the specs on the 2009 Ford Escape hybrid engine for example claim that it can run on 87 octane with a 12.3 to 1 static compression ratio by using an Atkinson Cycle style camshaft http://autos.yahoo.com/ford_escape_hybrid_fwd-specs/?p=allanother way to think of this is that the "dynamic expansion ratio" is 11 to 1 while the "dynamic compression ratio" is 8.5 to 1 due to late intake valve closure poor low rpm throttle response (bogging) is compensated for with the torque available from the electric traction motor
