318 wide block vs 318 small block cam. Interchangable ? #1519104
10/17/13 07:13 PM
10/17/13 07:13 PM
South Carolina
440_6_BBL Offline OP
South Carolina
Does anyone know if the LA small block hydraulic kit cams will work in the 318 poly engines ?
Re: 318 wide block vs 318 small block cam. Interchangable ? [Re: 440_6_BBL] #1519105
10/17/13 07:29 PM
10/17/13 07:29 PM
dogdays Offline
dogdays  Offline
No way. The valves are in different order.
You are looking at a regrind, which isn't a bad deal. I'd be talking to Bullet.
I believe some old school regrinders grind a quick hydraulic lobe on the solid lifter cams because they can get more lift if they eliminate the valve lash.
Chris Neilsen and Schneider are two of the traditional Poly cam regrinders, but I like the choice of grinds at Bullet, and the cost is reasonable, too.
Camshafts and intake manifolds are the two bugaboos waiting for you in Poly-land.
R.
Re: 318 wide block vs 318 small block cam. Interchangable ? [Re: dogdays] #1519106
10/17/13 09:07 PM
10/17/13 09:07 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The block on the Poly engine isn't any wider than the LA engine.
Re: 318 wide block vs 318 small block cam. Interchangable ? [Re: Kern Dog] #1519107
10/17/13 09:08 PM
10/17/13 09:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Thank you
Don't be the exception.
Re: 318 wide block vs 318 small block cam. Interchangable ? [Re: Supercuda] #1519108
10/18/13 11:23 AM
10/18/13 11:23 AM
scratchnfotraction Offline
I have used the crank/damper/t-chain/t-cover/fuel pump/oil pump/oil pan from a poly on a LA 318 before.
great way to score a steel 318 crank for a mid 80s LA318
Re: 318 wide block vs 318 small block cam. Interchangable ? [Re: scratchnfotraction] #1519109
10/18/13 03:51 PM
10/18/13 03:51 PM
dogdays Offline
dogdays  Offline
Poly rods and pistons will also work, but the Poly pistons are taller than the LA OEM pistons and may need valve notches cut in them, depends on the cam.
Back in the day, before there were many 318 higher compression pistons available, this was a favorite trick.
R.
