Re: EMC 2013 470 B stroker build
[Re: BradH]
#1518928
10/17/13 02:30 PM
10/17/13 02:30 PM
BradH
More questions: 1. What did the final volume of the chambers come out to? 2. How large was the dish in the pistons? 3. Can both the Procomp and Edelbrock Victor intake seats support a 2.25" intake valve? That's all for now...
[Re: RAMM]
#1518929
10/17/13 02:39 PM
10/17/13 02:39 PM
Posts: 1,051 The Great White North
RAMM
Here's a full pull with severe lifter instability. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1518931
10/17/13 02:43 PM
10/17/13 02:43 PM
RAMM
Here's a full pull with "better" valve control. J.Rob
[Re: RAMM]
#1518937
10/17/13 04:25 PM
10/17/13 04:25 PM
RAMM
This chart represents the very best port of all eight. The rest are down 3-6 cfm from this one at all points above .200" The exhaust flowed 250 cfm through the header. J.Rob
[Re: B3RE]
#1518941
10/17/13 06:12 PM
10/17/13 06:12 PM
BradH
... but if Mopar guys dont abandon the misinformation about valvetrain geometry, they will never be able to compete at the same level as the competition.
Please to elaborate, honorable B3RE-san.
[Re: pittsburghracer]
#1518942
10/17/13 06:13 PM
10/17/13 06:13 PM
Posts: 3,426 Toronto
mshred
Toronto
J. Rob nice work dude! Can see your extraordinary attention to detail leaving nothing spared
What did you think of those pro comp heads in terms of material quality when you ported on them as well as the casting quality i.e. how well bolt holes and such lined up, rocker shaft mounts level and not warped, etc.
If they are anything like the Chevy Pro comp heads I just did the aluminum is VERY hard.
Thats a good thing right? I have heard before that soft aluminum that cuts like better is not as good in terms of casting quality...but im not a head porter nor a metal guy, so I have no idea if thats true or not
[Re: mshred]
#1518943
10/17/13 06:22 PM
10/17/13 06:22 PM
BradH
If Jesse's were anything like my "porting dummy" BB head, the area under the exhaust valve seats don't have sufficient material to make a smooth transition into the bowls.
I don't know how poor the OOB valve job is because I had Brian at IMM put a "real" valve job on mine before I ever saw it. However, there is still a big "bowl hog" like cut under the intake valve insert that simply didn't need to be cut that deeply.
The short turns have a lot bigger "ledge" than the Edelbrock they copied which just adds to the porting time necessary to bring them around.
I know you're fishing for validation that buying Procomps is a good deal, but IMO they're perfect examples of how offshore "clone" products cut corners.
[Re: BradH]
#1518945
10/17/13 06:56 PM
10/17/13 06:56 PM
mshred
Toronto
The small block pro comp castings are supposed to be different then standard eddy's in that the water ports were moved in order to be able to port them and not hit water....otherwise, I think there is no real appeal to them...besides, im just asking, aint no harm in that lol
