Page 2 of 5 1 2 3 4 5
Re: EMC 2013 470 B stroker build [Re: BradH] #1518928
10/17/13 02:30 PM
10/17/13 02:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
More questions:
1. What did the final volume of the chambers come out to?
2. How large was the dish in the pistons?
3. Can both the Procomp and Edelbrock Victor intake seats support a 2.25" intake valve?
That's all for now...
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518929
10/17/13 02:39 PM
10/17/13 02:39 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Here's a full pull with severe lifter instability. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518930
10/17/13 02:42 PM
10/17/13 02:42 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What was the installed ICL of the 106 LSA cam? Thanks for posting your build.
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518931
10/17/13 02:43 PM
10/17/13 02:43 PM
RAMM Offline OP
RAMM  Offline OP
Here's a full pull with "better" valve control. J.Rob
Re: EMC 2013 470 B stroker build [Re: Sport440] #1518932
10/17/13 02:45 PM
10/17/13 02:45 PM
RAMM Offline OP
RAMM  Offline OP
It was essentially best straight up at 105.5
It was tried advanced 2 from there and it was down everywhere. J.Rob
Re: EMC 2013 470 B stroker build [Re: BradH] #1518933
10/17/13 02:49 PM
10/17/13 02:49 PM
RAMM Offline OP
RAMM  Offline OP
More questions:
1. Chambers were finished to 54cc
2. Dish with reliefs cc'd at 24 cc
3. Yes both can handle a 2.25" although you don't have much of a top cut on the seat ring. J.Rob
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518934
10/17/13 02:57 PM
10/17/13 02:57 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Sorry if this was covered, What rockers did you use for this build, and how much work was required to get them working with the head mods? Also would you expect the same/worse/better results with victors?
Re: EMC 2013 470 B stroker build [Re: pittsburghracer] #1518935
10/17/13 03:09 PM
10/17/13 03:09 PM
RAMM Offline OP
RAMM  Offline OP
I would LOVE to see a break-down of how much it cost to build an engine like this if a person had to buy all the parts and pay for all the machine work. Believe me guys this is not your average cheap 700 plus HP engine.
I never said it would be cheap to reproduce, especially for anyone without a machine shop at their disposal. What I did say is that it was low buck considering the parts utilized. Let's see.
1. Stock 400 block--free
2. Stock steel crank--$100.00 core
3. Scat I-beams stock Chevy dimensions-- $400
4. Icon pistons --$550
5. Mahle-Clevite 1/16" rings--$125
6. Pro-Comp Heads $800
7. Comp roller + Johnson lifters $1100
8. T&D rockers $1100
9. Truck oil pan and internal 1/2" p-u free
These are the core components that most would use to determine whether a build was exotic or more mundane. I know which column I would put this one in because I have a MUCH more exotic one here that cost triple this one in parts alone.
You are right when time is factored in though. I would have to charge a heck of a lot to duplicate this to justify the time.
What I am currently thinking about doing is giving it some compression, a 270 @ .050" solid roller, and a Dominator with matching spacer to see if it can produce 800+ hp. I think it will. J.Rob
Re: EMC 2013 470 B stroker build [Re: CTD5.9] #1518936
10/17/13 03:12 PM
10/17/13 03:12 PM
RAMM Offline OP
RAMM  Offline OP
I used T&D shaft rockers in a 1.6/1.6 ratio. The only work required was milling the shaft stand down .030" with a 7/8" ball endmill. I would expect better results with Victors because I have learned where I can improve from this build. J.Rob
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518937
10/17/13 04:25 PM
10/17/13 04:25 PM
RAMM Offline OP
RAMM  Offline OP
This chart represents the very best port of all eight. The rest are down 3-6 cfm from this one at all points above .200" The exhaust flowed 250 cfm through the header. J.Rob
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518938
10/17/13 05:48 PM
10/17/13 05:48 PM
USA
B3RE Offline
B3RE  Offline
USA
This is why you had instability. How many finalists had valvetrain issues with their hydraulic lifters? I'm sure they didn't just put the roller in the center of the valve and call it good. Not trying to be a jerk, I'd like to see you do well, but if Mopar guys dont abandon the misinformation about valvetrain geometry, they will never be able to compete at the same level as the competition.i
Kudos ony all the hard work on the cylinder heads, though. I like to see people thinking outside the box.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: EMC 2013 470 B stroker build [Re: B3RE] #1518939
10/17/13 06:04 PM
10/17/13 06:04 PM
Toronto
mshred Offline
mshred  Offline
Toronto
J. Rob nice work dude! Can see your extraordinary attention to detail leaving nothing spared
What did you think of those pro comp heads in terms of material quality when you ported on them as well as the casting quality i.e. how well bolt holes and such lined up, rocker shaft mounts level and not warped, etc.
Re: EMC 2013 470 B stroker build [Re: mshred] #1518940
10/17/13 06:11 PM
10/17/13 06:11 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If they are anything like the Chevy Pro comp heads I just did the aluminum is VERY hard.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: EMC 2013 470 B stroker build [Re: B3RE] #1518941
10/17/13 06:12 PM
10/17/13 06:12 PM
BradH Offline
BradH  Offline
... but if Mopar guys dont abandon the misinformation about valvetrain geometry, they will never be able to compete at the same level as the competition.
Please to elaborate, honorable B3RE-san.
Re: EMC 2013 470 B stroker build [Re: pittsburghracer] #1518942
10/17/13 06:13 PM
10/17/13 06:13 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Thats a good thing right? I have heard before that soft aluminum that cuts like better is not as good in terms of casting quality...but im not a head porter nor a metal guy, so I have no idea if thats true or not
Re: EMC 2013 470 B stroker build [Re: mshred] #1518943
10/17/13 06:22 PM
10/17/13 06:22 PM
BradH Offline
BradH  Offline
If Jesse's were anything like my "porting dummy" BB head, the area under the exhaust valve seats don't have sufficient material to make a smooth transition into the bowls.
I don't know how poor the OOB valve job is because I had Brian at IMM put a "real" valve job on mine before I ever saw it. However, there is still a big "bowl hog" like cut under the intake valve insert that simply didn't need to be cut that deeply.
The short turns have a lot bigger "ledge" than the Edelbrock they copied which just adds to the porting time necessary to bring them around.
I know you're fishing for validation that buying Procomps is a good deal, but IMO they're perfect examples of how offshore "clone" products cut corners.
Re: EMC 2013 470 B stroker build [Re: mshred] #1518944
10/17/13 06:27 PM
10/17/13 06:27 PM
PA.
"Little"John
"Little"John
PA.
You got me. I Googled it if you want to try to get something.
http://www.markusfarkus.com/reference/aluminum.htm
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: EMC 2013 470 B stroker build [Re: BradH] #1518945
10/17/13 06:56 PM
10/17/13 06:56 PM
Toronto
mshred Offline
mshred  Offline
Toronto
The small block pro comp castings are supposed to be different then standard eddy's in that the water ports were moved in order to be able to port them and not hit water....otherwise, I think there is no real appeal to them...besides, im just asking, aint no harm in that lol
Re: EMC 2013 470 B stroker build [Re: B3RE] #1518946
10/17/13 07:27 PM
10/17/13 07:27 PM
RAMM Offline OP
RAMM  Offline OP
How would you address the geometry issues with Mopar's shaft system. I am all ears. Short of milling the rocker stands down and moving the shaft in 2 of the 3 axis, I do not see how it can be done. Please enlighten me so I can understand. J.Rob
Re: EMC 2013 470 B stroker build [Re: RAMM] #1518947
10/17/13 08:33 PM
10/17/13 08:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
good job RAMM and excellent thread
