Does anyone know of a good carbureted magnum intake for use with stock 4bbl linkages, spreadbore carb and factory A/C?
This is going on an '82 Gran Fury LA318 w/ magnum heads.
If you have not already gotten the heads, the Engine Quest Magnum heads are available drilled and tapped for LA intakes. I have the version with the 2.02 intakes and using an Edelbrock intake with factory air. I got the heads from Clearwater Cylinder heads but they are also available from Hughes. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
