arc switch panel #1518377
10/16/13 12:57 PM
10/16/13 12:57 PM
nc
E
earthmover Offline OP
E
nc
http://www.jegs.com/images/photos/100/116/116-8000D.jpg
anybody using this switch panel in there race car???? how do you like it??????pros cons
Re: arc switch panel [Re: earthmover] #1518378
10/16/13 01:07 PM
10/16/13 01:07 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I like mine, affordable and easy to wire a car.
Re: arc switch panel [Re: Forest] #1518379
10/16/13 01:09 PM
10/16/13 01:09 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
I used them in my door cars, my current car just has a starter button and a mag. kill switch.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: arc switch panel [Re: Forest] #1518380
10/16/13 01:10 PM
10/16/13 01:10 PM
nc
E
E
nc
nice wiring thanks that's what I am looking for some good info and pics always help
Re: arc switch panel [Re: earthmover] #1518381
10/16/13 01:18 PM
10/16/13 01:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
I have the 4 switch version in my car, ignition and starter still run through the key. I like it, the switch panel is slick. You can swipe your finger across to turn them all off in a hurry if needed.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: arc switch panel [Re: earthmover] #1518382
10/16/13 01:35 PM
10/16/13 01:35 PM
Sterling Heights, MI
John_T_Brown Offline
Same here...
If it ain't broke fix it anyway!
Re: arc switch panel [Re: John_T_Brown] #1518383
10/16/13 02:23 PM
10/16/13 02:23 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I used some of their stuff in the past and it was ok. I haven't used any of the new stuff but I just don't really like the looks of the set up and I am not a big fan of the switches that they use. Just my
Back in the swing of things at Painless again! Great to be back!
Re: arc switch panel [Re: BJS racing] #1518384
10/16/13 02:51 PM
10/16/13 02:51 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I love that switch panel. The problem is the touch panel switches. I think they are sexy. But in a race car, when stuff hits the fan, (such as throttle hangs wide open or brakes fail) you have to have switches you can take a bat at with your hand and turn off without looking at them or thinking about it. (Don't ask me how I know.) Don't use this switch panel in a race car.
2011 Drag Pak Challenger
Re: arc switch panel [Re: rickseeman] #1518385
10/16/13 03:31 PM
10/16/13 03:31 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
You can program the switches with dip switches so that it will turn everything off when the Ignition switch is turned off. Mine is that way other than the Fan & Water pump stays on...
Still not the feel you want, but it is a option.
Re: arc switch panel [Re: rickseeman] #1518386
10/16/13 04:26 PM
10/16/13 04:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Or you can program them to all turn off with one button pushed.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: arc switch panel [Re: 1967dartgt] #1518387
10/16/13 05:12 PM
10/16/13 05:12 PM
Out West
408strokerdart Offline
Out West
This is how I have mine set-up. I love this switch panel and can hit the Ignition Off switch without looking. Membrane switches are good for more cycles than I will ever use in my lifetime. I do carry a spare system in my trailer though in case the board ever goes while at a race.
Re: arc switch panel [Re: earthmover] #1518388
10/16/13 07:33 PM
10/16/13 07:33 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I like mine...I have it set up so one switch kills everything.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: arc switch panel [Re: Adobedude] #1518389
10/16/13 09:07 PM
10/16/13 09:07 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I've got the 8 switch panel in my duster and like it a lot. Pretty affordable also.
Re: arc switch panel [Re: earthmover] #1518390
10/18/13 07:26 PM
10/18/13 07:26 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I really like mine. It was easy to install and a lot more affordable than the others out there.
Re: arc switch panel [Re: PLUM BAD] #1518391
10/18/13 08:50 PM
10/18/13 08:50 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Same here. Had them make me a 12 relay board to pair with the 12 switch panel and put all the interior lights, headlights, and park lights on that panel also. Wiring was really easy and the switches have a surprisingly positive feel to them.
Re: arc switch panel [Re: silverfish] #1518392
10/21/13 02:39 PM
10/21/13 02:39 PM
South Carolina
K
KRYPTONITE Offline
KRYPTONITE  Offline
K
South Carolina
I have installed a few of them and there Freaking awesome, I have used the painless and there's nothing painless about them! Ill never go back after using the ARC!! Simple, nice, light weight...... best thing since slice bread
Re: arc switch panel [Re: KRYPTONITE] #1518393
10/21/13 08:06 PM
10/21/13 08:06 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
I like the touch pad panel itself I just don't care for the ribbon cable.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
