Re: arc switch panel
[Re: Forest]
#1518379
10/16/13 01:09 PM
10/16/13 01:09 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
I used them in my door cars, my current car just has a starter button and a mag. kill switch.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: earthmover]
#1518381
10/16/13 01:18 PM
10/16/13 01:18 PM
Triple Threat
Renton Washington
I have the 4 switch version in my car, ignition and starter still run through the key. I like it, the switch panel is slick. You can swipe your finger across to turn them all off in a hurry if needed.
[Re: BJS racing]
#1518384
10/16/13 02:51 PM
10/16/13 02:51 PM
Posts: 2,630 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I love that switch panel. The problem is the touch panel switches. I think they are sexy. But in a race car, when stuff hits the fan, (such as throttle hangs wide open or brakes fail) you have to have switches you can take a bat at with your hand and turn off without looking at them or thinking about it. (Don't ask me how I know.) Don't use this switch panel in a race car.
2011 Drag Pak Challenger
[Re: rickseeman]
#1518385
10/16/13 03:31 PM
10/16/13 03:31 PM
Posts: 916 SE Washington
Forest
SE Washington
You can program the switches with dip switches so that it will turn everything off when the Ignition switch is turned off. Mine is that way other than the Fan & Water pump stays on...
Still not the feel you want, but it is a option.
[Re: 1967dartgt]
#1518387
10/16/13 05:12 PM
10/16/13 05:12 PM
Posts: 3,456 Out West
408strokerdart
Out West
Or you can program them to all turn off with one button pushed.
This is how I have mine set-up. I love this switch panel and can hit the Ignition Off switch without looking. Membrane switches are good for more cycles than I will ever use in my lifetime. I do carry a spare system in my trailer though in case the board ever goes while at a race.
[Re: earthmover]
#1518388
10/16/13 07:33 PM
10/16/13 07:33 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I like mine...I have it set up so one switch kills everything.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: KRYPTONITE]
#1518393
10/21/13 08:06 PM
10/21/13 08:06 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I like the touch pad panel itself I just don't care for the ribbon cable. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
