Re: Best exhaust manifold gaskets
[Re: scatpacktom]
#1518330
10/16/13 10:03 AM
10/16/13 10:03 AM
Posts: 75,090 A Banana Republic near you.
JohnRR
The best is none, mill the manifolds flat and put them on.
This is how the factory installed them originally.
Now I will have the manifolds milled flat , they are ALL warped ... except maybe NOS ... and use the gasket that comes in the fel pro gasket set.
[Re: floridian]
#1518331
10/16/13 07:47 PM
10/16/13 07:47 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Any suggestions on the best exhaust manifold gaskets for a 440 using stock exhaust manifolds?? And where to purchase them?
thanks
Remflex! www.remflex.com These are great gaskets.
[Re: floridian]
#1518335
10/17/13 01:26 PM
10/17/13 01:26 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Remflex work excellent. I can help you with them. I like the MR G Ultra Seals as well, but not as forgiving as the Remflex, but still a good gasket.
RIP Monte Smith
