Page 3 of 4 1 2 3 4
Re: X275 Challenger (READY TO RUMBLE) [Re: 408strokerdart] #1518161
10/16/13 05:52 PM
10/16/13 05:52 PM
ohio
all spooled up Offline
ohio
Awsome ride Marty. See you at Denton. They will be making rule changes/adding weight to slow you down before you know it." you know that thay all ways hit the mopars hard "
Re: X275 Challenger (READY TO RUMBLE) [Re: all spooled up] #1518162
10/16/13 06:47 PM
10/16/13 06:47 PM
San Angelo, Texas
W8n2DustU Offline OP
San Angelo, Texas
That would actually be good. I'm slightly over 3400# race ready. Everyone else will be at 3200# or less the next two weeks.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518163
10/16/13 07:06 PM
10/16/13 07:06 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Any idea how much power it makes? Or is it a secret.
By the way I really think the car is bad azz.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: X275 Challenger (READY TO RUMBLE) [Re: D-50] #1518164
10/16/13 07:27 PM
10/16/13 07:27 PM
San Angelo, Texas
San Angelo, Texas
Not yet but should make around 2100 hp. I know of other LF88 smallblocks that make at least that much power on the dyno.
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518165
10/16/13 07:30 PM
10/16/13 07:30 PM
San Angelo, Texas
San Angelo, Texas
Power won't be an issue. It's always power management and how good your converter works!
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518166
10/16/13 07:35 PM
10/16/13 07:35 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Thanks for the reply.. I hope to see it this weekend..
Re: X275 Challenger (READY TO RUMBLE) [Re: 408strokerdart] #1518167
10/16/13 11:34 PM
10/16/13 11:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Those turbos will get weight or outlawed for next year. They just went 4.50s at ducks race, in two separate cars. But go get them before you have to but a smaller one on.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518168
10/17/13 06:36 AM
10/17/13 06:36 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Pic2
good luck that is a beautiful car
Re: X275 Challenger (READY TO RUMBLE) [Re: Quicktree] #1518169
10/17/13 08:48 AM
10/17/13 08:48 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Congratulations Marty, the car turned out beautiful!
Hope all goes well first time out.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: X275 Challenger (READY TO RUMBLE) [Re: Plumb Wired] #1518170
10/17/13 09:12 AM
10/17/13 09:12 AM
Finland
mafo Offline
mafo  Offline
Finland
Looks like a 10 sec car
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: X275 Challenger (READY TO RUMBLE) [Re: 408strokerdart] #1518171
10/17/13 11:17 AM
10/17/13 11:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That would p**s me off bigtime
Re: X275 Challenger (READY TO RUMBLE) [Re: racerx] #1518172
10/17/13 11:04 PM
10/17/13 11:04 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
WOW, What a beautiful job. You should be very pleased with the way it turned out. Good luck with your testing.
Re: X275 Challenger (READY TO RUMBLE) [Re: 1967dartgt] #1518173
10/18/13 07:32 AM
10/18/13 07:32 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
That's 100% correct now that the end of the season is near,the turbo's are showing there true potetial.4.50's @ 160+ almost at will for the sharp crews.
Re: X275 Challenger (READY TO RUMBLE) [Re: fishy340] #1518174
10/18/13 10:24 AM
10/18/13 10:24 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Good luck Marty! Great looking car!
Re: X275 Challenger (READY TO RUMBLE) [Re: TheOtherDodge] #1518175
10/18/13 10:57 AM
10/18/13 10:57 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
well done and good luck mate,the car is a credit to you and your team
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: X275 Challenger (READY TO RUMBLE) [Re: Ian] #1518176
10/18/13 11:02 AM
10/18/13 11:02 AM
San Angelo, Texas
San Angelo, Texas
Well had the car up and running and getting ready to load to take to Hollysprings when it busted two teeth off the flywheel! Brand new billet flywheel from JW. I have to get with them first thing this morning and see about getting a new one before Denton.
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518177
10/18/13 01:09 PM
10/18/13 01:09 PM
San Angelo, Texas
San Angelo, Texas
There has been a change! The car is loaded and headed to Hollysprings for some shakedown passes today! Wish it LUCK! If anyone goes there please video it and let me know how its going!
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518178
10/18/13 01:13 PM
10/18/13 01:13 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I hate you marty...
Re: X275 Challenger (READY TO RUMBLE) [Re: W8n2DustU] #1518179
10/18/13 01:35 PM
10/18/13 01:35 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
And please post the video here so we all can see this bad boy run!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: X275 Challenger (READY TO RUMBLE) [Re: johnnycuda] #1518180
10/18/13 07:00 PM
10/18/13 07:00 PM
australia
charger410 Offline
charger410  Offline
australia
Hay! I was promised VIDEO
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Page 3 of 4 1 2 3 4
