Re: X275 Challenger (READY TO RUMBLE)
[Re: 408strokerdart]
#1518161
10/16/13 05:52 PM
10/16/13 05:52 PM
Posts: 1,049 ohio
all spooled up
ohio
Awsome ride Marty. See you at Denton. They will be making rule changes/adding weight to slow you down before you know it." you know that thay all ways hit the mopars hard "
[Re: all spooled up]
#1518162
10/16/13 06:47 PM
10/16/13 06:47 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
That would actually be good. I'm slightly over 3400# race ready. Everyone else will be at 3200# or less the next two weeks.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: W8n2DustU]
#1518163
10/16/13 07:06 PM
10/16/13 07:06 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Any idea how much power it makes? Or is it a secret. By the way I really think the car is bad azz.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1518164
10/16/13 07:27 PM
10/16/13 07:27 PM
W8n2DustU
San Angelo, Texas
Not yet but should make around 2100 hp. I know of other LF88 smallblocks that make at least that much power on the dyno.
[Re: W8n2DustU]
#1518165
10/16/13 07:30 PM
10/16/13 07:30 PM
W8n2DustU
San Angelo, Texas
Power won't be an issue. It's always power management and how good your converter works!
[Re: W8n2DustU]
#1518166
10/16/13 07:35 PM
10/16/13 07:35 PM
D-50
North, Alabama
Thanks for the reply.. I hope to see it this weekend..
#1518167
10/16/13 11:34 PM
10/16/13 11:34 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Those turbos will get weight or outlawed for next year. They just went 4.50s at ducks race, in two separate cars. But go get them before you have to but a smaller one on.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: W8n2DustU]
#1518168
10/17/13 06:36 AM
10/17/13 06:36 AM
Quicktree
Pic2
good luck that is a beautiful car
[Re: Quicktree]
#1518169
10/17/13 08:48 AM
10/17/13 08:48 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Congratulations Marty, the car turned out beautiful! Hope all goes well first time out. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
#1518171
10/17/13 11:17 AM
10/17/13 11:17 AM
Posts: 4,073 Mo.
racerx
Mo.
That would p**s me off bigtime
[Re: 1967dartgt]
#1518173
10/18/13 07:32 AM
10/18/13 07:32 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
That's 100% correct now that the end of the season is near,the turbo's are showing there true potetial.4.50's @ 160+ almost at will for the sharp crews.
[Re: Ian]
#1518176
10/18/13 11:02 AM
10/18/13 11:02 AM
W8n2DustU
San Angelo, Texas
Well had the car up and running and getting ready to load to take to Hollysprings when it busted two teeth off the flywheel! Brand new billet flywheel from JW. I have to get with them first thing this morning and see about getting a new one before Denton.
[Re: W8n2DustU]
#1518177
10/18/13 01:09 PM
10/18/13 01:09 PM
W8n2DustU
San Angelo, Texas
There has been a change! The car is loaded and headed to Hollysprings for some shakedown passes today! Wish it LUCK! If anyone goes there please video it and let me know how its going!
[Re: W8n2DustU]
#1518179
10/18/13 01:35 PM
10/18/13 01:35 PM
Posts: 861 lancaster,california
johnnycuda
And please post the video here so we all can see this bad boy run! If anyone goes there please video it and let me know how its going!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
