Re: Chassis dyno friday
[Re: all spooled up]
#1517930
10/15/13 07:15 PM
10/15/13 07:15 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
good luck are you runing the same header collectors
I cut off the collector all but where the pipes merg so the turnout that caused the reversion I believe is gone.I have 2.25" primary pipes.The shop with the dyno is one of the best header makers in the country so I hope for some input from him also.
[Re: CHAPPER]
#1517932
10/15/13 07:27 PM
10/15/13 07:27 PM
Clanton
northern,Ohio,USA
You might check out McBride's Auto for chassis dyno service too. They are located in Dover, Ohio.
Thanks!This dyno is only 3 miles from my house but ya never know.
[Re: Clanton]
#1517933
10/15/13 08:15 PM
10/15/13 08:15 PM
Posts: 1,049 ohio
all spooled up
ohio
with that cut off u should make some good power now
