Re: Let's build a small block around this cam.
[Re: Devilbrad]
#1517833
10/15/13 02:42 PM
10/15/13 02:42 PM
Posts: 43,161 Bend,OR USA
Cab_Burge
Many moons ago I had Scott at Straightline custom grind a solid roller cam for me. I was building a small cubic inch (.030" over stock stroke 318) nitrous motor with EFI and Edelbrock heads. Over the years I have sold off or traded pretty much all the parts for that build and all I have left is the cam, some Crower lifters, and have aquired a stock bore '69 340 block. I am thinking of building a 416 with some W5 or Indy 245cc heads. I would love to turbocharge it, but am unsure if these cam specs are suitable for that. Engine will be going in a 67 D100 pickup with a TKO 600 5 speed transmission and will have EFI. Discuss or tell me what you would build around this cam. Here is the cam card.
NEVR, EVER start a build based on one part Start the build with a goal in mind and then buy the parts you need to accomplish that goal I would build your motor the way you want it and then have that cam reground for the motor BTW, I have done what I said to not do and regretted it both times
[Re: moparman89]
#1517837
10/15/13 08:56 PM
10/15/13 08:56 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I would talk to Scott. But, I feel pretty sure a cam ground for a 318 is not going to work well with .690" of extra stroke. The way the engine fills the cylinder is going to be much different and need a different camshaft.
Leon
[Re: tubtar]
#1517839
10/15/13 09:29 PM
10/15/13 09:29 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I would put the cam in the for sale section, give yourself a clean sheet of paper, and start your build with no limiting factors like this particular cam would be. Scott, btw, doesn't grind cams, just calls up and has ground what he thinks might work, given a customers specs and intended usage. He just sells parts and services, kind of a middle man, unless something has changed I am not aware of. I tried him once, but had WAY better luck with Dwayne Porter.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Devilbrad]
#1517841
10/15/13 09:45 PM
10/15/13 09:45 PM
B3422W5
Portage,michigan
Probably be usable in a 340, mild compression, using a head with good mid lift flow. But wouldn't be a good choice on a 4 inch motor. Regards cam grinder, just correcting a mistake you made in your OP, you probably just worded it wrong, no biggie, bro
