cowl hood and air box #1517763
10/15/13 08:28 AM
10/15/13 08:28 AM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
I want to see pictures of air boxes that you guys have fabricated yourself, and talk about how you did it/what you used.
I have a cowl hood for my truck that I'd like to get painted and put on this winter. I would also like to make a box to shield the air filter/throttle body so that it only pulls air from the cowl, sealing the area in the cowl off from the rest of the engine bay (and heat)
**Photobucket sucks**
Re: cowl hood and air box [Re: 70Cuda383] #1517764
10/15/13 07:42 PM
10/15/13 07:42 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
here's one I made for a 4" cowl hood.
Re: cowl hood and air box [Re: 70Cuda383] #1517765
10/15/13 08:31 PM
10/15/13 08:31 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I will be watching this thread, as I do all air pan threads. I have been fighting this problem for awhile. I have tried to run a 6-pak scoop,,,with and without an air pan,,sealed and not sealed. I could not get it to perform as well as a cowl hood. I have found, that MY cowl hood, works best without an air pan sealed to the hood. It also runs better with an air filter than without an air filter. It runs the best with just an air filter and no air pan without the foam to seal to the hood. I would like to be able to Test/Tune at my local track on Friday nights,,but they don't treat the track for T/T, so you can't get much reliable info except on raceday. Good Luck!!
If you like drag racing, support your local track.
Re: cowl hood and air box [Re: CHAPPER] #1517766
10/15/13 09:59 PM
10/15/13 09:59 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I think a airpan on a cowl hood is a waste of time.But one thing I did and helped was cut a piece of plexiglass to cover the cat whiskers and drilled small holes in the plexiglass and used small wireties to block the air from going down them instead of going in the hood.Hope this helps Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: cowl hood and air box [Re: bdaz smblk] #1517767
10/15/13 10:23 PM
10/15/13 10:23 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I 'think' you gave me some info..by "cats whiskers", you mean the cowl vents,,right?? Never heard that one before!!
Re: cowl hood and air box [Re: CHAPPER] #1517768
10/15/13 10:34 PM
10/15/13 10:34 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Yes cowl vents haha.
Re: cowl hood and air box [Re: bdaz smblk] #1517769
10/15/13 10:39 PM
10/15/13 10:39 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
But make sure u put something on the carb vents.I put a 90* plugwire boot on both of my vent tubes and turn them too the front of the car so the air don't try to suck the fuel up out of them.
