Re: 2003 dodge dakota brake fitting size??
[Re: hp340nos]
#1517618
10/15/13 08:14 AM
10/15/13 08:14 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Dodge really messed up the brakes in my opinion.
the fittings at the master cylinder, RWAL/ABS solenoids, etc. are metric and use the odd bubble flares. --calipers also use metric banjo fittings, but the wheel cylinders used SAE double flare fittings.
**Photobucket sucks**
[Re: hp340nos]
#1517620
10/16/13 05:03 PM
10/16/13 05:03 PM
Posts: 921 Chicago illinois
ChinooK440
Chicago illinois
I went thru the same hassle on my 2000 ram a few years ago but i can,t remember what size the metric end of the adapters was but it was a bubble type flare. my local napa only had the adapters that came on a short piece of brake line which then you have to use a union as well which = to many connections. i ended up finding a large selection of the correct adapters that screw directly into the port/line end etc. at Orielly,s made by Plews. http://www.plews-edelmann.com/hydraulic-brake-fittings/
