Re: Roll cage question, Need help
[Re: The Sphinx]
#1517429
10/14/13 05:18 PM
10/14/13 05:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
The rear shock crossmember is considered part of the unibody frame. The crossmember is a U shaped channel that is welded to the frame rail and the floor is spotwelded to the lip on top. I have seen where the sheetmetal was cut out over the opening and plate welded in place. Then weld the tube to the plate. Also seen this done on rear frame rails. Actually this is how my first cage was done in my car. It was legal for cert every time it was checked. Was always told the 6X6 rule is for floorboards with no frame underneath.
Leon
[Re: modelmakerinc]
#1517431
10/14/13 08:55 PM
10/14/13 08:55 PM
Posts: 2,058 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
When Marty put the roll cage in my car, a few of the places I wanted tubes was not flat in a large enough area. He took the 6 x6 plates and bent them to match the floor and up the side of the inner rocker panel and welded them in place, then welded the tube where I wanted them. On the x-brace going to the rear shock cross member, he removed some of the sheet metal from over top of the crossmember, welded the tubes in place, then welded the sheet metal back in place. (The sheet metal was cut into two pieces to go around the tube)
Brian
[Re: modelmakerinc]
#1517432
10/15/13 12:18 AM
10/15/13 12:18 AM
Posts: 22,821 Bitopia
jcc
Bitopia
That looks like a nice weld job BTW And to the OP, your hidden question is, is 36 sq in the requirement or 6x6? I don't care about cert in my case, I have perimeter welded the plates to the floor, and then use a bunch of grade 8 3/16" allens to additionally sandwich the three pieces together.
[Re: Crizila]
#1517434
10/15/13 12:01 PM
10/15/13 12:01 PM
Posts: 20,722 in a cattle trailer down by th...
Guitar Jones
You can box it as crizila has or contour the plate to the floor. Either is acceptable.
