Help with fan shroud identification #1516254
10/12/13 06:27 PM
10/12/13 06:27 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I have a mopar fan shroud part number 373339. Any guesses on what this is from?
Re: Help with fan shroud identification [Re: gregok] #1516255
10/12/13 06:38 PM
10/12/13 06:38 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Any chance you are missing a digit? Mopar part#s are usually 7 digit, not 6.
Re: Help with fan shroud identification [Re: moparfan53] #1516256
10/12/13 08:23 PM
10/12/13 08:23 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
My bad, left out a digit. It should read 3733339. While i have your attention how about part numbers 3403884 and 3403885? I do have a Mopar dash trim piece with a five digit number made in your country, part # 71276. Any help with those would be appreciated.
Re: Help with fan shroud identification [Re: moparfan53] #1516257
10/12/13 10:47 PM
10/12/13 10:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, newer Mopar parts have 7 digits, or more. Older ones have 6 or less. Smaller the number the older the part is. Look at the part number for a crankshaft pilot bushing. Hint, it was originally used in the flathead 6's.
Don't be the exception.
Re: Help with fan shroud identification [Re: Supercuda] #1516258
10/12/13 11:06 PM
10/12/13 11:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Five digit numbers are usually the vender code, the ID for the vendor that made the part for Chrysler.
Re: Help with fan shroud identification [Re: Alaskan_TA] #1516259
10/12/13 11:45 PM
10/12/13 11:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I reiterate, the older the part, the smaller the part number. Not all Chrysler part numbers are 7 digits. 855646 for example, gas tank strap retaining nuts.
Re: Help with fan shroud identification [Re: Supercuda] #1516260
10/13/13 12:11 AM
10/13/13 12:11 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I was responding to this;
Lots of parts have five digit codes, but they are not all parts numbers.
I was not trying to discredit what you said in any way if that is how it looked?
Re: Help with fan shroud identification [Re: Alaskan_TA] #1516261
10/13/13 09:00 AM
10/13/13 09:00 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
My apologies, sometimes it's the craziest things.
Re: Help with fan shroud identification [Re: gregok] #1516262
10/13/13 11:10 AM
10/13/13 11:10 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I thought there was a good chance of a missing digit.
A Google search of 3733339 shows it as a rad shroud for early 90's trucks. Note; Adding "mopar" or "chrysler" to a Google part# search greatly helps by reducing the hits with phone numbers, patent numbers etc. Newest parts book I have is 1974 so I did not go any further.
https://www.google.ca/#q=3733339+mopar
Same type of search using #3403884/5 shows it was for 1970 model so checked my parts book for specifics. They are RH/LH rear "taillamp housing covers" for '70 Coronets except station wagons.
As already mentioned by Barry, the 5 digit# is probably not a part#.
-Alan
Re: Help with fan shroud identification [Re: moparfan53] #1516263
10/13/13 09:17 PM
10/13/13 09:17 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks for all the help guys!
Re: Help with fan shroud identification [Re: gregok] #1516264
10/13/13 09:18 PM
10/13/13 09:18 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
one pic can be worth more than a thousand numbers.
Re: Help with fan shroud identification [Re: bonefish] #1516265
10/14/13 04:14 PM
10/14/13 04:14 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
If my camera wasn't with my wife in Ohio I could oblige you,
