'72 Satellite Becoming a '71 RR "Clone" #1515976
10/12/13 02:11 AM
10/12/13 02:11 AM
Surface of the Sun, AZ
Hotwheelsjr Offline OP
of my next project.
Re: A Teaser... [Re: Hotwheelsjr] #1515977
10/12/13 07:55 AM
10/12/13 07:55 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
You're going to start painting Auto Art?
Re: A Teaser... [Re: 1fastrunner] #1515978
10/12/13 10:39 AM
10/12/13 10:39 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
International Truck?
Re: A Teaser... [Re: moparpollack] #1515979
10/12/13 11:20 AM
10/12/13 11:20 AM
LOL.
72 Satellite, southern AZ car, solid as you'll ever find. Has 71 fenders and tail lights. Drug it home yesterday.
Re: A Teaser... [Re: Hotwheelsjr] #1515980
10/13/13 06:58 PM
10/13/13 06:58 PM
Re: A Teaser... [Re: Hotwheelsjr] #1515981
10/13/13 10:39 PM
10/13/13 10:39 PM
85086
Lil Herman
Lil Herman
85086
Color , motor, etc what are you gonna do with it?
Re: A Teaser... [Re: moparpollack] #1515982
10/15/13 11:52 PM
10/15/13 11:52 PM
Current plans are to get it back together and properly titled -- probably a satin black paint job, polished Torq Thrust IIs, 400 or 440 (nothing wild). It has a dismantled title -- I have to get it back on the road and go through inspection to get a good title back on it. I'm just in the early stages of collecting parts now -- it probably won't see the road for a year.
Re: A Teaser... [Re: Hotwheelsjr] #1515983
10/16/13 12:20 AM
10/16/13 12:20 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Are you going to use tape of staples to put the title back together?
JB Rhinehart, Realist
A-Body's RULE!
Re: A Teaser... [Re: Rhinodart] #1515984
10/16/13 11:34 AM
10/16/13 11:34 AM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
Nice project. I recognize that trailer, it's Marks (azmopar)
Re: A Teaser... [Re: azblackhemi] #1515985
10/16/13 12:50 PM
10/16/13 12:50 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It looks like it was originally A4. Great color. I hope it goes back to that color some day. Good luck with it!
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515986
11/02/13 12:59 AM
11/02/13 12:59 AM
Ok...starting to dig into this thing now. The "right" coast guys are gonna hate, cuz haters gonna hate.
Car was originally bought in Tucson and bounced back and forth between Tucson and Phoenix its entire life, so I'm told. It's definitely a southwest desert car...99% rust free. I drug it home from south of Tucson. Originally a 318 car. Plan is a big block...either a 400 or 440, of which I have both.
Previous owner knew it had a 8.75 sure grip of sorts in it, possibly a spool...someone has definitely put some time and money into the rear, but I haven't dropped the pig yet to see what carrier it is. I did the "spin the wheels and count the yoke revolutions" the other day and it appears to have 3.91's in it.
So, without further ado, here are some pics of what I'm starting with.
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515987
11/02/13 01:03 AM
11/02/13 01:03 AM
Pics of it at home after I started dismantling:
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515988
11/02/13 01:06 AM
11/02/13 01:06 AM
Started some blasting today...look at that beautiful rust free metal!
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515989
11/02/13 01:41 AM
11/02/13 01:41 AM
Wow.......pretty clean body, shouldn't take long.
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: ] #1515990
11/02/13 01:51 AM
11/02/13 01:51 AM
Yeah, clean as a whistle. Length of time to fix 'er up will depend on my motivation.
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515991
11/02/13 01:54 AM
11/02/13 01:54 AM
Fender Tag:
E44 318-2 Barrel
D34 TorqueFlite Automatic Transmission
RH23
R = Plymouth Belvedere/Satellite
H = High
23 = 2 Door Hardtop
G2G
G = 318 150HP(net) or 155HP(net) 1-2BBL 8 CYL
2 = 1972
G = St. Louis, MO, USA
GY4 Paint Code: Light Gold
F1Y3
Trim Grade/Style/Color
F = F Class
1 = Cloth and Vinyl Bench
Y3 = Light Gold
GY4 Upper Door Frame: Light Gold
516 Date Built: 5 / 16 / 1972
EW1 Roof Type OR Color: White / Alpine White
U Built to Specifications for USA Order
G11 Tinted Glass All
G35 Delete Standard Outside Mirror
H51 Single Air /w Heater
J25 3 Speed Variable Wipers
J52 Inside Hood Release
L31 Hood / Fender Mount Turn Signal
M21 Roof Drip Rail Moldings
M33 Body Side Moldings
N23 Electronic Ignition 72 only
R21 Solid State AM / FM
V02 Two Tone Paint
26 26 in. Radiator
END End of Codes
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515992
11/02/13 10:46 AM
11/02/13 10:46 AM
Well the weather you have in Arizona during winter should be enough to motivate you no.............. This car should look good when done as you did a wonderful job on the cuda.
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: ] #1515993
11/02/13 12:20 PM
11/02/13 12:20 PM
Ty sir.
The plan is to get some more blasting done today...hopefully the entire front clip minus the suspension -- those will get done when I pull it all off the car to do a disc brake swap (it has 4-wheel drums now). The inner fenders and firewall should go pretty quick -- the old paint is blasting off very easily.
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515994
11/03/13 01:08 AM
11/03/13 01:08 AM
Did some more blasting today, but no pics to share. The blaster was giving me fits, so I spent some of the afternoon taking apart the sand dispenser...found some curly-q thread looking thing stuck in the ball valve. By the time I got it all put back together light was fading fast, so I wrapped it up for the day.
I did blast a bit on the driver side floor and found some very minor rot. Deciding what to do as they are very small holes...I don't want to replace the whole pan, but don't want to do a cob job either. When we did my daughter's Barracuda, we filled a couple of small holes with lead...you'd never know by looking at it. We'll see.
Re: '72 Satellite Becoming a '71 RR "Clone" [Re: Hotwheelsjr] #1515995
11/03/13 07:17 PM
11/03/13 07:17 PM
Gonna need a small patch...
