OBD II Code readers #151571
11/16/08 12:15 PM
11/16/08 12:15 PM
St Louis, Missouri
Runnin74 Offline OP
Runnin74  Offline OP
St Louis, Missouri
I looking to buy a code reader to take care of my family's daily driver Mopar, Toyota, and Nissan vehicles. I've never owned one before and recently had to go to the local parts store to get the codes read for my Caravan evap emissions problems. I know they will all petty much read out the codes, but what I don't know is how much of a code reader I want. In other words what do some of the more expensive code readers do for you and do I need what they do? Can you check O2 sensors with a coder reader, can you reset the check engine lite with standard code readers? What am I looking for in a code reader to take care of my family's cars? Any manufacturers better than others?
TIA
Re: OBD II Code readers [Re: Runnin74] #151572
11/16/08 12:27 PM
11/16/08 12:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A reader does just that.It tells you the codes.You need a scanner to see live data.The reader just tell you what set a code like the O2 or emissions.Scanners used can be bought but most need updates for newer cars as they come out.Expect to paty probally 600 bucks for a decent used scanner.Then if it needsa updates they cost also.Rocky
Chrysler Firepower
Re: OBD II Code readers [Re: Runnin74] #151573
11/16/08 11:28 PM
11/16/08 11:28 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I am curious too Greg, so here is a
Re: OBD II Code readers [Re: Jwilli500] #151574
11/17/08 12:07 AM
11/17/08 12:07 AM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
This one will probably do everything that you want it to do and other brands just like it are available at parts stores also.
http://cgi.ebay.com/ebaymotors/OBD-2-AUT...omotiveQ5fTools
OBD2/CAN is alot different than OBD1.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: OBD II Code readers [Re: wildman340] #151575
11/17/08 08:53 AM
11/17/08 08:53 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I have a cheapie Actron scanner. I thought it told me the whole story. Turns out chryslers will read off the codes in the Odometer if you quickly go off to run 3 times.
The car showed more codes than the scanner and also I found that the scanner showed codes the car didn't!!
I keep it because it still erases codes OK.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: OBD II Code readers [Re: CJK440] #151576
11/17/08 12:50 PM
11/17/08 12:50 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Don't buy a cheap scanner. I went through three that were SUPPOSED to cover all OBD-I cars. Well the car I needed it for (89 LeBaron GTC TII) was not covered in the first two and the third will only read stored codes like the dash. I need to rebuild the engine, but after that I will probably look for a used scanner that will do the job.
Re: OBD II Code readers [Re: Jim_Lusk] #151577
11/20/08 11:26 PM
11/20/08 11:26 PM
Arkansas
GregGarner Offline
GregGarner  Offline
Arkansas
I've seen some USB scanner/code readers and Linux drivers for them. Does anyone know which one of these scanners work well?
GregGarner
www.rt-eng.com
Home of the mopar solid state limiter adn tach repair kit
Re: OBD II Code readers [Re: GregGarner] #151578
11/21/08 08:48 PM
11/21/08 08:48 PM
St Louis, Missouri
Runnin74 Offline OP
Runnin74  Offline OP
St Louis, Missouri
I'd like to know that as well. A laptop and linux - way to go!
Re: OBD II Code readers [Re: Runnin74] #151579
11/21/08 09:19 PM
11/21/08 09:19 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
without getting 2 crazy on brands and price, I bought the newest actron scanner out there...
Re: OBD II Code readers [Re: Runnin74] #151580
11/21/08 09:19 PM
11/21/08 09:19 PM
You may want to look at a Scangauge. They work as a scanner, but can also be run continuosly as a selectable gauge. I am going to get on for the new campervan to monitor rpm, trans temp, etc as this thing is hauling around 9K pounds. $160 on Amazon, free shipping.
http://www.scangauge.com/
Re: OBD II Code readers [Re: AARCONV] #151581
11/23/08 08:12 PM
11/23/08 08:12 PM
Washington Twp., Southern NJ
Fastfrankie Offline
Fastfrankie  Offline
I did the same. A guy sold me a brand new Actron he claimed was given to him as a gift - I'm sure it was a five fingered discount. I bought the Actron 9180 in the sealed plastic box for $60. I believe it retails for $135.
I also have a Snap On MT2500 updated to 2003 and does up to 2008 global...
