Re: Driveshaft length
[Re: johnfin]
#1515680
10/11/13 09:38 PM
10/11/13 09:38 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Same as with a 727 and a 8 3/4..
I am truckless..
[Re: 340SHORTY]
#1515681
10/12/13 02:15 AM
10/12/13 02:15 AM
Posts: 3,922 n.e. pa.
65rbdodge
n.e. pa.
yup tell them that when you order it. clear as mud.
[Re: MPerry]
#1515684
10/12/13 12:36 PM
10/12/13 12:36 PM
Posts: 7,197 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Personally I wouldn't order a driveshaft without filling out one of those forms with all the measurements. http://www.dynotechengineering.com/downloads/1%20Pc%20Driveshaft%20Trans%20to%20CL.pdf
Agreed, don't take an on-line measurement as the number for your car...Spring arch,driveline combos/angles etc... Will make the measurements different.. A little off one way or the other means problems... Car sitting at ride height take the measurements using the sheet in the above link for the most problem free solution...
[Re: 65rbdodge]
#1515685
10/12/13 06:23 PM
10/12/13 06:23 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I think what 340SHORTY was referring to, but did not elaborate on, was that a '69 GTX was not available with an A833/8.75 combo so would not be in a FSM or parts book. If the OP had either of those books he could refer to the 727/8.75 combo, as it is the same length driveshaft.
The FSM and the parts book show 51.50" (same as the link cnxt posted).
