Good hemi/mopar mechanic in norcal/bay area? #1515656
10/11/13 08:44 PM
10/11/13 08:44 PM
Petaluma, CA
JimDiesel Offline OP
Petaluma, CA
I am looking to have some tuning work done on my hemi. It is a 472 crate hemi with a single demon carb. I don't seem to be able to get it to run right. It is running rich, and seems down on power. I'd like to have a pro check it out so I don't damage anything.
I woudl greatly appreciate any recommendations for a reputable shop to get this thing running like it should. With Sears Point nearby I figure there must be some good places around.
68 Road Runner
67 Coronet
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: JimDiesel] #1515657
10/12/13 12:31 AM
10/12/13 12:31 AM
It ain't run right since it was built or a recent development? Started after any particular work done on it or part changes/settings. Especially if from day 1 I'd suggest starting from scratch & a compression/leakdown tests/degreeing the cam. Note the initial/total & when (RPM) the total comes in. What cam. Possible vac leak.You mentioned running rich, float levels/float saturation/floats hanging up in their travel/what power valve/idle fuel psi/vac at idle. There ain't no mysteries & there is a cause & we CAN find it
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: RapidRobert] #1515658
10/12/13 01:55 PM
10/12/13 01:55 PM
Petaluma, CA
Petaluma, CA
Thanks for your response. I have to admit I am slightly intimidated to work on the thing. I have limited experience and if I do something stupid I probably can't afford to fix it. If I can't find a reputable shop, I will dig in myself. I don't have much in the way of automotive tools so I will need to invest in some.
I believe that both issues have existed for some time. The engine sure doesn't seem to have power that it should. I think it has been running rich for a while. My dad and I worked on it together quite a few years ago and it has been sitting since then.
68 Road Runner
67 Coronet
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: JimDiesel] #1515659
10/12/13 02:49 PM
10/12/13 02:49 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: Joesixpack] #1515660
10/12/13 02:54 PM
10/12/13 02:54 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: Joesixpack] #1515661
10/14/13 02:44 PM
10/14/13 02:44 PM
California
mickm Offline
mickm  Offline
California
gordon anderson. master mechanic, fabricator. when you see the all aluminum hemi in his 64 polar, you'll understand.
650.637.9515
tell him mickey sent you...
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: JimDiesel] #1515662
10/14/13 03:27 PM
10/14/13 03:27 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The best Hemi guy in NoCal is Harry Holton...
Located in Modesto, phone is 209.527.1568
Without a doubt one of the best builders/tuners for Gen II Hemis
He is semi-retired but still luvs to work on these...
Just my $0.02....
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: Sinitro] #1515663
10/14/13 03:53 PM
10/14/13 03:53 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Modesto again with Steve Wann and Regitta Bros...
Tony
70 AARCuda Vitamin C
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: 70AARcuda] #1515664
10/14/13 10:40 PM
10/14/13 10:40 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Spelled Rettig Bros.
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: mickm] #1515665
10/14/13 11:28 PM
10/14/13 11:28 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
650.637.9515
You can not go wrong with Gordon Anderson. He is one of the best Mopar mechanic you will ever meet!
Tell him Mickey and Stu sent you!
Re: Good hemi/mopar mechanic in norcal/bay area? [Re: MidPenMopar] #1515666
10/15/13 12:02 AM
10/15/13 12:02 AM
Petaluma, CA
Petaluma, CA
awesome.
Thanks guys
68 Road Runner
67 Coronet
