Time for wheelie bars #1515580
10/11/13 06:35 PM
10/11/13 06:35 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
Got some good bite last time out. Whos wheelie bars should I be looking at? The RJ racing stuff looks nice.Opinions please.
And no .. the oil pan didnt survive
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Time for wheelie bars [Re: 540CUDA] #1515581
10/11/13 07:13 PM
10/11/13 07:13 PM
organ
maximum entropy Offline
organ
i have slipped the surely bonds of earth...
Re: Time for wheelie bars [Re: 540CUDA] #1515582
10/11/13 08:18 PM
10/11/13 08:18 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
What was you 60' on that pass? What kind of pan were you running? Love your ride
Re: Time for wheelie bars [Re: 540CUDA] #1515583
10/11/13 08:19 PM
10/11/13 08:19 PM
Penna
70satelliteguy Offline
Penna
Here is where I got mine from!
http://www.swracecars.com/store/view-item-search.aspx?Search=wheelie%20bars
"And no .. the oil pan didnt survive"
Did you get scared and let off ?
Mike
Re: Time for wheelie bars [Re: 70satelliteguy] #1515584
10/11/13 09:32 PM
10/11/13 09:32 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Skinny Kid Race cars out of Michigan is what I use.
Re: Time for wheelie bars [Re: Sammy] #1515585
10/11/13 09:59 PM
10/11/13 09:59 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
80" wheelie bars from Skinny Kid
Re: Time for wheelie bars [Re: Wv68charger] #1515586
10/11/13 11:28 PM
10/11/13 11:28 PM
Corvallis,OR
540CUDA Offline OP
super street
540CUDA  Offline OP
super street
Corvallis,OR
The timeslip said 1.004 for the 60'. Im not sure thats possible. It was a modified Charlies 10qt dragster pan. 1" too deep.
Thanks for the info. Here's a pic near the 60ft timer.
Re: Time for wheelie bars [Re: 540CUDA] #1515587
10/11/13 11:59 PM
10/11/13 11:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Spend a few minutes under the car measuring where to put them on the rear axle; on my car, I ended up narrowing the ones I bought. Still, much cheaper than the 300' ride on the rear bumper.
Re: Time for wheelie bars [Re: topside] #1515588
10/12/13 12:53 AM
10/12/13 12:53 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Keep your foot in it and keep shifting
Pans usually get crunched by lifting while wheels up
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Time for wheelie bars [Re: B3422W5] #1515589
10/12/13 08:07 AM
10/12/13 08:07 AM
Mi USA
Dyno Donnie Offline
Dyno Donnie  Offline
Mi USA
Skinny Kid bars here 60 inch -1.27 sixty ft. I always talk to
Keith at Skinny Kid before adding or subtracting anything from
my chassis
Re: Time for wheelie bars [Re: Dyno Donnie] #1515590
10/12/13 09:22 AM
10/12/13 09:22 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Santhuff front shocks and four link adjustment, but thats me...
We're allowed a max of 48" bars and at that point it'll unload the chassis so above suggestion become necessary.
SS/DA 1924
Re: Time for wheelie bars [Re: SSDAcuda] #1515591
10/12/13 09:29 AM
10/12/13 09:29 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Before:
After:
SS/DA 1924
Re: Time for wheelie bars [Re: SSDAcuda] #1515592
10/12/13 09:36 AM
10/12/13 09:36 AM
Q
Quicktree Offline
Quicktree  Offline
Q
why not just spend some time adjusting the car? try lowering your launch rpm or chassis tuning?
Re: Time for wheelie bars [Re: Quicktree] #1515593
10/12/13 10:52 AM
10/12/13 10:52 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If your oil pan did not survive no higher wheelie than that you must have let out, broke, or shifted into high. Hey we all have been there. Well I never lift unless the wall is approaching. But, I have broke something and slammed the car down pretty hard. I keep telling people them ole cheap traction bar snubbers bolted in place of the stock lower control arm bumps is a great insurance policy.
I would try adjusting the car for a longer/lower IC. A 60" wheelie bar works well. Don't be mislead wheelie bars although used for wheelie limiting are best suited for controlling the load on the rear tire. In situations where you can only run a 48" they need to be spring loaded to keep from suddenly unloading the rear tire.
Judging from the car pictured I'm pretty sure you staged with the rear tires to get that 60 ft time. If that is your true 60 ft I would not change a thing other than lifting. Ride that baby to the 330 if you are 60 ft-ing 1.0's.
Leon
Re: Time for wheelie bars [Re: Leon441] #1515594
10/12/13 03:43 PM
10/12/13 03:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the old spring loaded bars for one reason. To keep from damaging the pan, headers, and diaper. They are set low and touch on every pass. they don't seem to unload the rear tires either. As you can see from this pic their touching even with the front end low. It does come up about a 12"-16". My car runs very similar to yours. 1.32/9.25/146.6
Doug
Re: Time for wheelie bars [Re: dvw] #1515595
10/12/13 04:23 PM
10/12/13 04:23 PM
Guitar Jones Offline
62" bars from ART.
