Page 1 of 3 1 2 3
8 3/4 axle twisted #1515471
10/11/13 03:50 PM
10/11/13 03:50 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
With the new engine in my 67 Barracuda, I went to track and twisted the housing. The 408 dynoed 606hp at 6300rpm and 553 lbs at 5100 rpm.
The housing gave up, so there are 3 options for me:
1-Change the housing and brace it with the mopar brace
2-Go with a Moser axle housing cut to length
3-Go with a Dana 60
I already have 35 spline spool and axles
What would be my best option for reasonable price ? Any ideas welcome............
I'm running ladder bars
Dan
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515472
10/11/13 04:08 PM
10/11/13 04:08 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Either Moser housing or brace another stock one, depending on what you want to spend. Braced stock one one would live fine IMO.
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515473
10/11/13 04:11 PM
10/11/13 04:11 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I would recommend the Dana 60 solution. You should be able to reuse your 35 spline axles and brakes. Truck Dana housings are easy to find for less than $200.00. Make sure the side carrier bearing has not spun in the housing to avoid additional machining costs (common problem, easily fixed). You will need to buy a new spool, bearings, seals, gears, companion flange, housing ends, ladder bar mounts, and shorten the driveshaft, but altogether (with your existing axles and brakes) you should be able to permanently solve your rear end troubles for less than $1,000.00. Check with Dr. Diff on prices. And you could sell the 8&3/4 carrier and spool to make up for a lot of the difference. And once you have a bullet-proof rear end, you can almost forget about the major reason that 727s explode.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 8 3/4 axle twisted [Re: 451Cuda] #1515474
10/11/13 06:17 PM
10/11/13 06:17 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I run a braced 8-3/4" in my junk. I do not run a transbrake. Best 60' 1.42, normally 1.45. I made the brace myself from a piece 6.0" X 2.0" X 1/8" RETU along with a little help the tube laser at work. I have never had any issues. However I do not think I would run a brake with that set up.
Re: 8 3/4 axle twisted [Re: Polarapete] #1515475
10/11/13 06:45 PM
10/11/13 06:45 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hummmmmmmmmmm........
Re: 8 3/4 axle twisted [Re: Polarapete] #1515476
10/11/13 06:51 PM
10/11/13 06:51 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
This
We run this same set-up, 30 spline axles even. We have been 1.28 60ft (no transbrake) and our rearend troubles are gone. We twisted a backbraced 8 3/4 and broke multiple pumpkins which led to broken sprags.. Once you add more power you will be glad you went dana..
Casey
Re: 8 3/4 axle twisted [Re: Whompin_Wedge] #1515477
10/11/13 07:00 PM
10/11/13 07:00 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I agree with the Dana, best thing I did ! Don't get me wrong we ran the 8 3/4 back braced spool axles and didn't break but I was worried ! Weight kills them ! If you can sell off what you have and get the Dana !
Re: 8 3/4 axle twisted [Re: 70dusterjohn] #1515478
10/11/13 07:12 PM
10/11/13 07:12 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
And from what model truck should I get a cheap housing and best supplier for parts ?
I take it the Dana from trucks are sufficient ?
Dan
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515479
10/11/13 07:20 PM
10/11/13 07:20 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
I would not put any money into an 8.75! Dana or 9". If you ever upgrade to a higher HP engine the Dana or 9" will hold up. The rear is one part that overkill is good.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515480
10/11/13 07:32 PM
10/11/13 07:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
Dan
If you can find a truck or van dana 60 housing that has the three (3.0) diameter axle tubes buy it quick take your time looking, if you can't find one of those then look at buying the next size axle tubes that are 3 1/8, some are even 3 1/4 diameter , I would stay away from them BTW some fo the GM and GMC early(1970 and earlier ) 3/4 ton pickups had those and I think even some of the early Dodge and Ford pickups had them also. I'm not exactly sure when Dana Corp. started making the Dana 60 with 3 1/8 axle tubes
Re: 8 3/4 axle twisted [Re: Cab_Burge] #1515481
10/11/13 07:38 PM
10/11/13 07:38 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Will I be able to retain my 35 splines axles from my 8 3/4 ?
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515482
10/11/13 08:04 PM
10/11/13 08:04 PM
I had Strange 35 spline race axles special made to work with the stock A body 8 3/4 housing with the strange 35 spline 8 3/4 spool, I twisted that rascal(houusing) up horribly with no back brace. I swapped the axles over to the truck Dana 60 I had narrowed and I had to cut about 3/8 inch off the end of one axle, so yes you can reuse your 35 Spline axles in the Dana 60 with the 35 spline Strange, Dutchmen, Yukon and many other spools Make sure and check for end play, don't let the axles butt in the center The exception might be the Mark Williams 35 spline spool with thier different axle and spool teeth angle, 30 degree versus maybe 45 degree angles, not sure which one is which
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515483
10/11/13 08:05 PM
10/11/13 08:05 PM
COLUMBUS, OH
W
W
COLUMBUS, OH
Yes you can, you have to put 8 3/4 ends on the dana. Brakes will work too.
Casey
Re: 8 3/4 axle twisted [Re: Whompin_Wedge] #1515484
10/11/13 08:13 PM
10/11/13 08:13 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Casey
Duh !! of course it will fit ! loll haven't thought of that so far lollll
Cab burge is saying my spool will fit in a Dana ???
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515485
10/11/13 08:23 PM
10/11/13 08:23 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
After that, will I need to brace the housing or special welding to the Dana ?
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515486
10/11/13 08:25 PM
10/11/13 08:25 PM
Casey
NO Not even close, sorry But your 35 spline axles (brakes and brake drums will fit on the new ends also) in most 35 spline spools BTW, make sure and mark your axles(right and left) when you take them out of the 8 3/4 and put them in the new cut down Dana 60 on the same side thay came out of so you don't try and run them backwards to what they've been run already
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515487
10/11/13 08:26 PM
10/11/13 08:26 PM
COLUMBUS, OH
W
W
COLUMBUS, OH
I believe we had to change spools..
But there is no need to backbrace the dana
Casey
Re: 8 3/4 axle twisted [Re: Wedgeman] #1515488
10/11/13 08:48 PM
10/11/13 08:48 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
put a dana in it and forget about having issues with your rear...
Re: 8 3/4 axle twisted [Re: DusterKid] #1515489
10/11/13 08:51 PM
10/11/13 08:51 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
convincing enough...........!
Re: 8 3/4 axle twisted [Re: Whompin_Wedge] #1515490
10/11/13 08:53 PM
10/11/13 08:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have Moser 35 spline 8 3/4 axles in my Dana 60 with a Moser spool with no issues at all
Gus
64 Plymouth Savoy
Dana 60
Page 1 of 3 1 2 3
