no oil pressure on first start up #151456
11/15/08 08:26 PM
11/15/08 08:26 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
i have a 72 340 that was freshly built and running for a short time before i got it, but mice got in it and filled the intake with corn, so i tore it back down, cleaned everything and put it back together. i got it running again and im not getting oil pressure at idle and only about 20psi when its revved up a little. i prelubed it with a drill once before and i got about 20 psi. the engine is now in my 94 dakota and the oil pan is very hard to remove. im looking for any advise for things to check without pulling the pan. any help would be great
Re: no oil pressure on first start up [Re: 72dak] #151457
11/15/08 08:39 PM
11/15/08 08:39 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Much as you dont want to hear it, you have to pull the pan. I went through the same thing with a 360 I bought. With the pan off I found a half a dozen dead mice in the bottom and a few in the pick up tube screen. Previous owner had drained the oil and left it empty. The mice made a cemetery there. Is your Dakota a engine swap, if so it should not be to hard to just pull the whole engine. My 90 engine swap was pretty easy and I plan on doing it again once I get an oil pan for my 408.
Re: no oil pressure on first start up [Re: Posest] #151458
11/15/08 08:53 PM
11/15/08 08:53 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
i took the engine all the way down pistons,heads,oil pan and all. it should be completely clean as far as that goes. its a new pickup and its been sealed up tight since i put it back together so mice couldnt get in again. it just wouldnt make any pressure so i changed guages and it didnt change.theres no leaks externally and the engine sounds fine. im at a loss
Re: no oil pressure on first start up [Re: 72dak] #151459
11/15/08 09:14 PM
11/15/08 09:14 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
is the plug installed behind the cam plate?
Re: no oil pressure on first start up [Re: ademon] #151460
11/15/08 09:20 PM
11/15/08 09:20 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
it should be i dont know why i would have had to remove it
Re: no oil pressure on first start up [Re: 72dak] #151461
11/15/08 09:48 PM
11/15/08 09:48 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I bought a motor that the plug had been left out of. I found it when I primed the motor, Oil poured on to the distbutor gear location when I turned the oil pump.
Re: no oil pressure on first start up [Re: sbhpcb] #151462
11/15/08 09:53 PM
11/15/08 09:53 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
when u said running for a short time...how short was that and did it have oil pressure then?...
Re: no oil pressure on first start up [Re: AARCONV] #151463
11/15/08 09:58 PM
11/15/08 09:58 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
it was in a car for about a year and i would assume it had oil pressure. the guy who had it built it right and had alot of cash in it i dont see why he would run it without oil pressure
Re: no oil pressure on first start up [Re: 72dak] #151464
11/15/08 10:06 PM
11/15/08 10:06 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Do you have a remote oil filter?
It sounds like a vehicle with crossed remote oil filter lines to me..??
If no remote filter and the valley end plugs are in it's a tough guess..
CrAzYMoPaRGuY
Re: no oil pressure on first start up [Re: CrAzYMoPaRGuY] #151465
11/15/08 10:10 PM
11/15/08 10:10 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
theres no remote filter i just have a 90 degree adapter
Re: no oil pressure on first start up [Re: 72dak] #151466
11/15/08 10:14 PM
11/15/08 10:14 PM
Canada
Canada
Did you check the oil pickup screen?
Sorry, but I ain't up to speed on your situation yet!
CrAzYMoPaRGuY
Re: no oil pressure on first start up [Re: CrAzYMoPaRGuY] #151467
11/15/08 10:16 PM
11/15/08 10:16 PM
Canada
Canada
Have you tried an independant mechanical gauge into the back of the block?
Have you tried priming it with a priming tool with an independant mechanical gauge?
CrAzYMoPaRGuY
Re: no oil pressure on first start up [Re: 72dak] #151468
11/15/08 10:24 PM
11/15/08 10:24 PM
yes a tough one. you might pull the dist/intermediate shaft/oil filter & spin the pump(CW) w a priming shaft & see how much flow you have at the 90 degree adapter as you spin the drill at varying speeds which would let you see whats up at the beginning of the pressure side. If good I'd pull the intake & prime it again & see what you see.
Re: no oil pressure on first start up [Re: CrAzYMoPaRGuY] #151469
11/15/08 10:24 PM
11/15/08 10:24 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
yeah the pickup is brand new. it never ran with the mouse nest in it, but i decided to tare it all the way down anyway to make sure i wouldnt have problems. all i did was pull the intake, heads and pistons, cleaned them and put it back together
Re: no oil pressure on first start up [Re: 72dak] #151470
11/15/08 10:29 PM
11/15/08 10:29 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
maybe the pressure relief valve is stuck open?,it happened to me on a ford and also on a chevy
Re: no oil pressure on first start up [Re: CrAzYMoPaRGuY] #151471
11/15/08 10:31 PM
11/15/08 10:31 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
all i had was a mechanical guage, so i tried another one and i still had no pressure. i took the whole setup and hooked it up to my old worn out 318 van and i was getting almost 40 psi at idle, but it was cold. either way my mechanical guages are obviously fine.
Re: no oil pressure on first start up [Re: rhad] #151472
11/15/08 10:33 PM
11/15/08 10:33 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
is the pressure relief right in the pump?
Re: no oil pressure on first start up [Re: 72dak] #151473
11/15/08 10:36 PM
11/15/08 10:36 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
What did the bearings look like when you pulled the pistons? Did you pull any mains to see what they looked like?
Re: no oil pressure on first start up [Re: stumpy] #151474
11/15/08 10:42 PM
11/15/08 10:42 PM
wisconsin
72dak Offline OP
72dak  Offline OP
wisconsin
i looked at all the bearings since it was apart and they all looked good. overall every part i took out looked almost new, but i didnt actually pull the cam or crank
Re: no oil pressure on first start up [Re: 72dak] #151475
11/16/08 12:30 AM
11/16/08 12:30 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
once i had a reman chevy that seemed to have pressure when you used a drill to prime the pump,but it wouldnt show any on the gauge,turns out there is a small soft plug that fits in the oil galley that directs oil thru the filter,the plug was out of place as in pushed up to far ,and the oil would go thru the filter but wouldnt get to the bearings or the gauge,does dodge have a similar setup??,seems like they might
