Re: no oil pressure on first start up
[Re: 72dak]
#151464
11/15/08 10:06 PM
11/15/08 10:06 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Do you have a remote oil filter?
It sounds like a vehicle with crossed remote oil filter lines to me..??
If no remote filter and the valley end plugs are in it's a tough guess..
CrAzYMoPaRGuY
[Re: 72dak]
#151466
11/15/08 10:14 PM
11/15/08 10:14 PM
CrAzYMoPaRGuY
Canada
Did you check the oil pickup screen? Sorry, but I ain't up to speed on your situation yet!
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#151467
11/15/08 10:16 PM
11/15/08 10:16 PM
CrAzYMoPaRGuY
Canada
Have you tried an independant mechanical gauge into the back of the block? Have you tried priming it with a priming tool with an independant mechanical gauge?
CrAzYMoPaRGuY
[Re: 72dak]
#151468
11/15/08 10:24 PM
11/15/08 10:24 PM
RapidRobert
yes a tough one. you might pull the dist/intermediate shaft/oil filter & spin the pump(CW) w a priming shaft & see how much flow you have at the 90 degree adapter as you spin the drill at varying speeds which would let you see whats up at the beginning of the pressure side. If good I'd pull the intake & prime it again & see what you see.
