Master Cylinder #1514513
10/09/13 02:35 PM
10/09/13 02:35 PM
canada
W2-408 Online content OP
W2-408  Online Content OP
canada
Its time to replace the master cylinder in the race car, its been in the car for about 15 years now, for the life of me i can't remember what to use as an application when getting a new one, factory discs up front and stock drums on the Dana out back. What does everybody else ues? Yes its the aluminium one with 2 mounting bolts... Thanks in advance!
Re: Master Cylinder [Re: W2-408] #1514514
10/09/13 04:03 PM
10/09/13 04:03 PM
I would check the inner bore size and replace it with one of the same size, if your happy with the old one If you want more stopping with less pedal pressure, make the new one have a smaller bore size by 1/16 to 1/8 or so Years ago I made the mistake of buying a master cylinder with a bigger bore size than I took off on a race car with a old iron dual master cylinder because I was racing the car at the Winternationals and in a hurry to get it fixed for the next day The parts store didn't have the direct replacement one but they had both the next size smaller and bigger. I picked the bigger one, bigger is always better , right? Wrong on hydraulics cylinders and pressures I really had to use a lot of pedal pressure to get that rascal to stop at the end after the change
