best place to buy torque converter #1514432
10/09/13 11:38 AM
10/09/13 11:38 AM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Need to be directed as to where the best place to buy a torque converter for a 1970 440-6. New, re manufactured??? Sponsors on here? What color were they painted too?
Re: best place to buy torque converter [Re: tcat446] #1514433
10/09/13 12:06 PM
10/09/13 12:06 PM
Here good about Frank Lupo of dynamic transmissions. In your neck of the woods also (Berlin/Newark New Jersey). Wouldn't be cheap tho
Re: best place to buy torque converter [Re: tcat446] #1514434
10/09/13 03:14 PM
10/09/13 03:14 PM
Those converters are exteranly balanced originally So make sure, unless you have a internally balanced six pak motor, that you get the correct externally balanced converter for your motor Good luck, BTW you could probally use a B&M externally balanced flex plate but I have heard bad things about them on here
Re: best place to buy torque converter [Re: Cab_Burge] #1514435
10/09/13 03:26 PM
10/09/13 03:26 PM
Tacoma, Washington USA
Adam71Charger Offline
Cab, if someone had an externally balanced 440, lost there original Torque Converter for that motor, how would that person get the correct balanced TQ? Are they different for each factory engine? Or did every engine from a certain year/run (say 440+6's made in 1970 for roadrunners) get the same TQ?
I used Turbo Action when I bought my first TQ. I think I talked to the owner. They were very knowledgeable and got me the right converter for my specific setup. It is near impossible to find the right TQ without talking to the manufacturer and giving them all the info on your car. It's not like picking an intake out of a edelbrock catalog.
Re: best place to buy torque converter [Re: Adam71Charger] #1514436
10/09/13 04:59 PM
10/09/13 04:59 PM
SE PA
Yellow Fever Offline
SE PA
I usually have the local convertor company (Pat's for me) go through my old one.
Re: best place to buy torque converter [Re: tcat446] #1514437
10/09/13 05:32 PM
10/09/13 05:32 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
PTC Performance Torque Converters. They are Mopar guys. Good stuff at good prices.
Master, again and still
Re: best place to buy torque converter [Re: DaveRS23] #1514438
10/09/13 05:43 PM
10/09/13 05:43 PM
GEORGIA
barracuda7199 Offline
GEORGIA
I really like my PTC converter. Talk to Kenny good mopar people
Re: best place to buy torque converter [Re: tcat446] #1514439
10/09/13 07:43 PM
10/09/13 07:43 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
For a good quality converter off the shelf Hughes Performance makes a dang nice one with a very reasonable price. Their Street Master 2500 works like a stock converter and will flash to 2,500 RPM or even higher depending on the torque of the engine and rear gears.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: best place to buy torque converter [Re: Junky] #1514440
10/09/13 09:24 PM
10/09/13 09:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a Luppo Dynamic converter and it has worked very good for me. Ron
Re: best place to buy torque converter [Re: 383man] #1514441
10/10/13 12:44 AM
10/10/13 12:44 AM
Ripley, NY
tcat446 Offline OP
tcat446  Offline OP
Ripley, NY
Thanks for the replies everyone!
Trying to keep it all original as possible. Not looking for a higher stahl converter. Still the same people all of you mentioned??
What color was the tranny suppose to be painted?
Re: best place to buy torque converter [Re: tcat446] #1514442
10/10/13 08:42 AM
10/10/13 08:42 AM
PA
BTTG Offline
BTTG  Offline
PA
727 TF's are cast aluminum... no paint. mopar action had a nice article in the Feb 2013 issue (I think) about restoring the finish on aluminum parts. article was based on discussions with dave walden.
