1994 Jeep Wrangler No power to fuel pump ? HELP #1514196
10/08/13 09:36 PM
10/08/13 09:36 PM
Pennsylvania
scannman70 Offline OP
Pennsylvania
I put a new fuel pump in the wrangler when I had the tank out.
Now back together, turn it over no fuel to motor.
I cut into wire harness back by the tank, added a jumper wire, and a extra ground.
unhooked fuel line under jeep, ran into a gas can,
added power to jumper direct from battery.
Fuel pump kicks on, fuel like crazy out the line.
Also changed fuel pump relay under hood in fuse panel.
Turn jeep over, no power to pump. no fuel
Ideas ??
Thank you
Re: 1994 Jeep Wrangler No power to fuel pump ? HELP [Re: scannman70] #1514197
10/09/13 10:51 AM
10/09/13 10:51 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Do you have spark? if not, you'll need to start diag with the ASD circuit.
Re: 1994 Jeep Wrangler No power to fuel pump ? HELP [Re: J_BODY] #1514198
10/09/13 01:15 PM
10/09/13 01:15 PM
Pennsylvania
Pennsylvania
Have spark,
No fuel ?
