Re: budget 440 build with rpm heads, good cam choice? [Re: Dunnuck Racing] #1513713
10/08/13 01:09 PM
10/08/13 01:09 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I'd plan to change springs. Pretty much any modern cam of the sizes being tossed around (except the MP .528) will need more spring pressure than the factory RPM springs. There's a reason there are always sets of those for sale.
I'd 3rd or 4th the 275HL. It's not a lot of coin and will work well with what you have - except the valve springs. Keep the static ratio below 10:1 and the quench less than .035" and you'll be stylin'.
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513714
10/08/13 03:10 PM
10/08/13 03:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Did COMP manage to tame the ramps down on the XE###HL series, or are they the same noisy crash-the-valve-train-prematurely junk the original .842-type XE hydraulics are?
Re: budget 440 build with rpm heads, good cam choice? [Re: BradH] #1513715
10/09/13 11:28 PM
10/09/13 11:28 PM
jersey
Spaceman Spiff Offline OP
jersey
Would it be worth contacting porter racing, compu-flow or modern cylinder head, and having them spec a cam? I won't mind paying more, if it means i will be getting the best for my application.
I'm going to have the block checked out, and go from there. Perhaps I can get the pistons and related items from them as well, so I know it's all a matched combination.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513716
10/10/13 10:56 AM
10/10/13 10:56 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I believe Dwayne Porter will have just what the Dr. ordered.
Getting old just means you were smarter than some and luckier than others.
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513717
10/10/13 12:10 PM
10/10/13 12:10 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Maybe call Jim at Racer Brown,too. He won't steer you wrong.
Re: budget 440 build with rpm heads, good cam choice? [Re: dannysbee] #1513718
10/10/13 02:18 PM
10/10/13 02:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes he did the cam in my 493. Ron
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513719
10/10/13 02:54 PM
10/10/13 02:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looking at no more than 10.2 with the available pistons. We have 93 octane here.
Thanks for the input everyone. Pleas keep it coming.
I personally see no reason for a custom cam at this level but that`s me............
