budget 440 build with rpm heads, good cam choice? #1513693
10/07/13 08:39 PM
10/07/13 08:39 PM
jersey
Spaceman Spiff Offline OP
jersey
The 413 in the wagon is making some not so good noises.
I was given a '74 440m block thats already been .030 over. Going to have it checked out and see if it will clean up with a hone, or needs to go over a tad more.
Going to use the crank and rods from the 413, and order a kit with pistons, rings, bearings, etc.
I have a set of rpm heads, 84cc., a performer rpm intake, 850 holley vacuum secondary, 2,600 stall ptc converter, and 3.73 gears.
what would be a good cam to take advantage of the rpm heads? I have indy rockers also.
Willing to go up on the stall if need be, but it is a budget build, so no roller cam. would like to try to keep all cost with machine work around $2,000. A friend is doing the assembly, he just doesn't have a tools for the machine work. Rebuild kit with good pistons is about $800, so that leaves some room for extras, not including a new converter.
Don't want to go stroker, because that at least $2,000 just for the kit, then it all must be checked and balanced, and i would also need to redo my fuel system at that point.
Thanks for any help you guys can give.
Car weighs about 4,300lbs and will have a/c.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513694
10/07/13 09:25 PM
10/07/13 09:25 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Mopar 284/528 is what I'd use.
Nautilus Racing-
Re: budget 440 build with rpm heads, good cam choice? [Re: Chris2581] #1513695
10/07/13 09:28 PM
10/07/13 09:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used the MP .557 cam in my old mild 440 with 906 heads. It dipped in the 11.40's in my 3700 lb 63. Ron
Re: budget 440 build with rpm heads, good cam choice? [Re: 383man] #1513696
10/07/13 09:32 PM
10/07/13 09:32 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
What's your compression with the 84cc heads? I put together a similar combo over the summer and went with the MP .557 solid. The car is an animal compared to what it was with the .528 solid and 906 heads.
Re: budget 440 build with rpm heads, good cam choice? [Re: 383man] #1513697
10/07/13 09:35 PM
10/07/13 09:35 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Comp Cams XE275HL. 231/237 @ .050, 525 lift. on 110, Great street cam.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: budget 440 build with rpm heads, good cam choice? [Re: 383man] #1513698
10/07/13 09:41 PM
10/07/13 09:41 PM
Saint Charles, MO
P
pleasantk Offline
pleasantk  Offline
P
Saint Charles, MO
Have a stock bottom end 440 in my 68 GTX with your heads and intake and an 850DP. Had a .557 Purple Shaft and currently have a Racer Brown .520. Running 4200 stall. Went low 12's with the .557 and run 11.60's with the .520. Both worked great for street/strip. Shift at 56-5700.
Re: budget 440 build with rpm heads, good cam choice? [Re: MoparBilly] #1513699
10/07/13 10:04 PM
10/07/13 10:04 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I built a 383 stroker (440 length stroke, 440 length rods, short pistons) at .060 over on the 383 block, it was basically a .010 under 440 stuffed into a 383 block.
eddy heads out of the box, RPM intake, 10.5 compression with flat top pistons at zero deck, .039 fel pro head gaskets.
Torque was flat at over 500 ft lbs from 3000 rpm through about 5400 rpm before it started to trickle off, peak torque was 535 ft lbs at around 3800 rpm.
Hp peaked around 5600-5800 rpm at 505hp.
(numbers are engine dyno)
I think for a mild street build, you'll love that XE275HL.
**Photobucket sucks**
Re: budget 440 build with rpm heads, good cam choice? *DELETED* [Re: Spaceman Spiff] #1513700
10/07/13 10:11 PM
10/07/13 10:11 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Post deleted by Dunnuck Racing
Re: budget 440 build with rpm heads, good cam choice? [Re: Dunnuck Racing] #1513701
10/07/13 10:19 PM
10/07/13 10:19 PM
jersey
jersey
Looking at no more than 10.2 with the available pistons. We have 93 octane here.
Thanks for the input everyone. Pleas keep it coming.
Re: budget 440 build with rpm heads, good cam choice? *DELETED* [Re: Spaceman Spiff] #1513702
10/08/13 12:00 AM
10/08/13 12:00 AM
Northern Indiana
Northern Indiana
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513703
10/08/13 12:25 AM
10/08/13 12:25 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I don't know Keith, When I read the OP, I immediately thought, "He wants to run 9's on 2 stages!" But maybe I was reaching a little...
Re: budget 440 build with rpm heads, good cam choice? [Re: MoparBilly] #1513704
10/08/13 12:30 AM
10/08/13 12:30 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Stage 1... Large... Stage 2... Huge
Kevin
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513705
10/08/13 12:31 AM
10/08/13 12:31 AM
Monroeville Ohio
Traven Offline
Traven  Offline
Monroeville Ohio
I am running those heads, home ported with 9:5 CR on a 440 with a solid Cam from Racer Brown with 254@.050 duration .554 Int .525 exh lift. 1.6 rockers on Int.. My challenger is@ 3800 lbs with me in it. With 4.30 gears and an 8" ATI converter I run 11.20s @ 119-121 mph. Think it may be a little quicker with 4.10s. This is through mufflers and ET street radials.
Re: budget 440 build with rpm heads, good cam choice? [Re: Dunnuck Racing] #1513706
10/08/13 12:41 AM
10/08/13 12:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
You state no roller which is fine,but do you want a solid or hydraulic flat tappet? Power brakes a concern? Smooth idle and good vacuum a priority ?
People tend to suggest a cam they use and like without knowing what your intentions are.
Keith
the cam I had provided enough vacuum for my power brakes. I don't know how it would do if an AC compressor kicked on a idle though--if that would lug the motor down too much...
I was also running a stick shift, but with a mild stall, I think that cam will do fine with an auto
Re: budget 440 build with rpm heads, good cam choice? [Re: 70Cuda383] #1513707
10/08/13 12:52 AM
10/08/13 12:52 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Keith
The cam you and Billy suggest would be a good one IMO.
RPM intake
4300#
3.73 gear
AC/cruiser
2600 stall/ willing to change though.
Vacuum carb.
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513708
10/08/13 12:56 AM
10/08/13 12:56 AM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
Depending on the cam you can go higher than that with aluminum heads.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: budget 440 build with rpm heads, good cam choice? [Re: d7cook] #1513709
10/08/13 07:33 AM
10/08/13 07:33 AM
jersey
jersey
No power brakes. Rough idle is not a concern. I'd prefer a hydraulic, but am open to a mechanical, as long as I don't need the added expense of changing out a lot of parts I already have to support it. Rather not change springs and rockers if I can help it.
Re: budget 440 build with rpm heads, good cam choice? [Re: Dunnuck Racing] #1513710
10/08/13 07:36 AM
10/08/13 07:36 AM
jersey
jersey
Also am running an MSD pro billet, blaster coil, and digital 6aL box. And am limited to 2.5 exhaust do to under car clearance issues, not being a unibody car.
Re: budget 440 build with rpm heads, good cam choice? [Re: Spaceman Spiff] #1513711
10/08/13 12:22 PM
10/08/13 12:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I ran 10.0 comp with 906's but I used KB quench pad pistons and had quench so no ping even at 38 total. Ran fine on 92 pump. I also used power brakes with the MP .557 cam and they worked fine but my 63 does have a good size brake booster. Ron
Re: budget 440 build with rpm heads, good cam choice? *DELETED* [Re: MoparBilly] #1513712
10/08/13 12:51 PM
10/08/13 12:51 PM
Northern Indiana
Northern Indiana
