Page 2 of 3 1 2 3
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Challenger 1] #1513640
10/07/13 09:54 PM
10/07/13 09:54 PM
Delray beach, Florida
P
Performance Only Offline OP
P
Thanks for sharing. Do you think it would have lived with just .006" off? Is .002" enough to worry about one way or another?
Can you take .008 off the top of the pistons if you can't do it with head gaskets?
It "might" have lived at that point, but this little guy will push 28#'s of boost. That's quite a bit when you consider what's actually holding the head down. As far as the pistons go, with the way they're designed (crowned)it would me near impossible to cut them down.
machine shop owner and engine builder
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513641
10/07/13 09:59 PM
10/07/13 09:59 PM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
That's why I use the new raloc bristle disks.Made from plastic so they don't cut the metal.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
Re: Do you use Roloc discs to clean gasket surfaces? [Re: bdusted440] #1513642
10/07/13 10:39 PM
10/07/13 10:39 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Them are just as bad. they are harder than you think. I have seem lot of bad things from both. everyone ask me why I keep all them wore out ones in my box. a little comment sense go's a long way when using these things . most of the new stuff I use scottbite pads by hand. they come in 8x8 sheets and I cut them in to 4 pieces.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: wldtm] #1513643
10/07/13 10:55 PM
10/07/13 10:55 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
................................................(if) a flat rate technician has touched it (it) probably had a (several) roloc bristle or scotch style touch (all over) the engine.
If anyone has a better (faster) way ( while the "flat rate" time clock is ticking) to clean a sealing surface.........................., I am all ears.(me too!)
Thanks for the picture
Justin
.......( Ricky. Been there, done that for too many years)
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Copper Dart] #1513644
10/07/13 11:16 PM
10/07/13 11:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
After being a Flat rate guy for over 30 years I can say this. Yes if you're not very careful you can get enough grit in a motor to cause damage. Yes if you hold a disc in one spot long enough it's not going to be flat. Small diameter discs and worn discs make the problem worse. I never had an intake or head gasket comeback. As a flat rate tech it always pays worse when doing the the job a second time for free. If they didn't work I would have never used them. That being said, inexperienced hands can do a lot of damage in a hurry. Now a blue printed performance engine, different story. Not even the same animal.
Doug
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Copper Dart] #1513645
10/07/13 11:16 PM
10/07/13 11:16 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there are places where using them is appropriate, deck/head surfaces isn't one of them and i never use them where the abrasive and/or scrap is going to get into the engine
i go through a lot of razor blades, can be a little tricky on aluminum you just need to be careful
Re: Do you use Roloc discs to clean gasket surfaces? [Re: jamesc] #1513646
10/07/13 11:31 PM
10/07/13 11:31 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Super Scraper!
http://www.goodson.com/SS-4U-1-1_4_Wide_Super_Scraper
Scotch brite is for cleaning the grill and doing body work.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Jeremiah] #1513647
10/07/13 11:40 PM
10/07/13 11:40 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
Is that an alloy or iron block?
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Scott58] #1513648
10/08/13 12:41 AM
10/08/13 12:41 AM
P
P
It's an iron block.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513649
10/08/13 01:17 AM
10/08/13 01:17 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That first picture was after taking .004 off the deck. In this one you can see more clearly where the Roloc disc dug in a little harder. Obviously the blue spots are the LOW spots.
IMO, The pics arent proving your point. I see very large Uniform Diameter impression marks of different depths in the first two pics.
Evidence of a bad hand rolex disc clean up would be less uniform and sporatic.
In your First pic, the Cylinder tops are untouched by your first shave but the deck clearly shows a wide diameter pattern impression. On the Second cut the "one cylinder" shows the same pattern of the wide diameter cutting impression that the Deck shows on the First cut.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513650
10/08/13 03:10 AM
10/08/13 03:10 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
And even more important if the block has been O-ringed is to avoid this!!!! I use a flat file to remove the remains on the surface. Everything you use that is compressible (like sandpaper or similar) will try to round off corners and although we are talking about margins, that could be critical. Thanks for sharing this!!
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Oyvind Mopar] #1513651
10/08/13 08:25 AM
10/08/13 08:25 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
No offense Dan - there is merit in a warning about using them improperly. That being said if he removed .060 of iron with a rotoloc he used more than a couple and certainly more than what was needed to remove a gasket. Maybe he was trying to remove the indent from the fire ring?
A monkey can destroy anything by not giving a crud.
I see nothing wrong with using the correct abrasive or "finger" disc sapringly to clean off residue, being careful to keep the debris out of the bores and coolant jacket. That is what the directions say to do... Me and thousands of others have been using them since they came out with no results like that when care is taken to do it right.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: moper] #1513652
10/08/13 08:56 AM
10/08/13 08:56 AM
P
P
He didn't remove .060, more like .006-.007. I've been using abrasive discs for decades, the point here is that the deck of a block or head is not a good place to use them IMO. Buy the way, no offense taken.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513653
10/08/13 11:15 AM
10/08/13 11:15 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Ok I have to ask, what kind of engine was this anyway?
Re: Do you use Roloc discs to clean gasket surfaces? [Re: GTX MATT] #1513654
10/08/13 12:13 PM
10/08/13 12:13 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
good post,and after working just 5months working only with dose disks and polishingmachines it has become very obvious that that kind of disks are horrible for that kind of use,its just as evident when polishing a surface to a mirrorsurface after using Roloc disks..
Re: Do you use Roloc discs to clean gasket surfaces? [Re: 1Fast340] #1513655
10/08/13 01:04 PM
10/08/13 01:04 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
lol.. I must have misread somewhere in there. Sorry Dan.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: dvw] #1513656
10/08/13 10:47 PM
10/08/13 10:47 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
Doug
Agreed!
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: Do you use Roloc discs to clean gasket surfaces? [Re: wldtm] #1513657
10/09/13 07:02 AM
10/09/13 07:02 AM
michigan woods
imfixinmopars426 Offline
michigan woods
thanks for the warning...been using them for years,and yes...common sense goes a long way!!! anything abrasive,spinning 20,000 rpm can do some damage.never had anything come back by using them,but I never used one like a angle grinder either,lol...mike
Re: Do you use Roloc discs to clean gasket surfaces? [Re: imfixinmopars426] #1513658
10/09/13 07:33 AM
10/09/13 07:33 AM
Truckville, the capital of NY
85_Ram_4speed Offline
I was warned about these when going to school for Chrysler. I work for Cummins now (not wrenching now though), and they don't want us using them either, but they approve of the scotchbrite pads----which will put just as much garbage in the engine, but is easier on the deck surfaces doing it by hand vs a roloc on a die grinder. We have issues with protruding / dropped liners, so being carful on these engines is important.
The plastic bristle ones are approved though, but again, material gets flung all over, and yes, they can do damage to the surface too, albeit less IMO.
I am guilty of using them on decks, have for years, but I try very hard to keep it moving and not stay in one spot (kinda like leaving a belt sand in one spot on a piece of wood). Anyways, maybe its time to look at changing my methods when concerning deck surfaces.
Outcast Dodge guy.
Re: Do you use Roloc discs to clean gasket surfaces? [Re: Performance Only] #1513659
10/09/13 10:13 AM
10/09/13 10:13 AM
Az
Crizila Offline
Crizila  Offline
Az
Could you please post a picture of a Roloc disc - the type used that caused the damage. Thanks.
Fastest 300
Page 2 of 3 1 2 3
