Re: Do you use Roloc discs to clean gasket surfaces?
[Re: bdusted440]
#1513642
10/07/13 10:39 PM
10/07/13 10:39 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
That's why I use the new raloc bristle disks.Made from plastic so they don't cut the metal.
Them are just as bad. they are harder than you think. I have seem lot of bad things from both. everyone ask me why I keep all them wore out ones in my box. a little comment sense go's a long way when using these things . most of the new stuff I use scottbite pads by hand. they come in 8x8 sheets and I cut them in to 4 pieces.
[Re: Oyvind Mopar]
#1513651
10/08/13 08:25 AM
10/08/13 08:25 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
No offense Dan - there is merit in a warning about using them improperly. That being said if he removed .060 of iron with a rotoloc he used more than a couple and certainly more than what was needed to remove a gasket. Maybe he was trying to remove the indent from the fire ring? A monkey can destroy anything by not giving a crud. I see nothing wrong with using the correct abrasive or "finger" disc sapringly to clean off residue, being careful to keep the debris out of the bores and coolant jacket. That is what the directions say to do... Me and thousands of others have been using them since they came out with no results like that when care is taken to do it right.
[Re: Performance Only]
#1513653
10/08/13 11:15 AM
10/08/13 11:15 AM
Posts: 5,169 CT
GTX MATT
CT
Ok I have to ask, what kind of engine was this anyway?
[Re: imfixinmopars426]
#1513658
10/09/13 07:33 AM
10/09/13 07:33 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I was warned about these when going to school for Chrysler. I work for Cummins now (not wrenching now though), and they don't want us using them either, but they approve of the scotchbrite pads----which will put just as much garbage in the engine, but is easier on the deck surfaces doing it by hand vs a roloc on a die grinder. We have issues with protruding / dropped liners, so being carful on these engines is important.
The plastic bristle ones are approved though, but again, material gets flung all over, and yes, they can do damage to the surface too, albeit less IMO.
I am guilty of using them on decks, have for years, but I try very hard to keep it moving and not stay in one spot (kinda like leaving a belt sand in one spot on a piece of wood). Anyways, maybe its time to look at changing my methods when concerning deck surfaces.
Outcast Dodge guy.
#1513659
10/09/13 10:13 AM
10/09/13 10:13 AM
Posts: 7,506 Az
Crizila
Az
Could you please post a picture of a Roloc disc - the type used that caused the damage. Thanks.
Fastest 300
