storing car for winter #1513500
10/07/13 02:26 PM
10/07/13 02:26 PM
South Carolina
carhunter Offline OP
South Carolina
Here we are at the end of the car season, and just like some opinions on storing your car for the winter.I would like to know how many of you start your car or just cover it and leave to till spring.Any feed back would be great thanks.
mike.
Re: storing car for winter [Re: carhunter] #1513501
10/07/13 02:30 PM
10/07/13 02:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
mike.
I toss a bottle of seafoam in it and drive it over to my MIL garage and park it. Disconnect the battery and go over and start it about every 6-8 weeks. That's it, I don't even change the oil until I have about 8000 miles on it which takes about 3 years.
I change my anti freeze more often now than my oil with aluminum heads on it.
Re: storing car for winter [Re: Challenger 1] #1513502
10/07/13 02:52 PM
10/07/13 02:52 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I don't do anything, just park it in an unheated garage or trailer and start it in the spring, been doing it for decades with no issues. Even with the crap gas nowadays it haven't had an issue.
JB Rhinehart, Realist
A-Body's RULE!
Re: storing car for winter [Re: Rhinodart] #1513503
10/07/13 06:59 PM
10/07/13 06:59 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Me too, with all my engines. Zero problems. Except my garage is heated.
Re: storing car for winter [Re: JonC] #1513504
10/07/13 07:10 PM
10/07/13 07:10 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Storage prep consists of a mad dash to finsih all the proejcts I started during the summer.
To prep, I vacuum the car out, check the air in the tires, check the antifreeze and oil. I toss a can of Seafoam in the tank and top it off. Drive it to the Fairgrounds on a warm sunny day, park it in the dairy barn, disconnect the battery and put a car cover over it.
It overwinters in unheated, locked space with a hundred or so other collector cars. About every 4th year, I need a new battery.
Astrobuf
So, are you really a Rocket Scientist?
Re: storing car for winter [Re: astrobuf] #1513505
10/07/13 07:46 PM
10/07/13 07:46 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Storage? What's that? I drive mine every chance I get during the winter. At least once every 2 to 3 weeks when the weather breaks for a day or two. I enjoy my car too much to let it set all winter long! It's in the garage next to my wife's Neon to keep it company.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: storing car for winter [Re: Junky] #1513506
10/07/13 07:51 PM
10/07/13 07:51 PM
IN
ahy Offline
ahy  Offline
IN
For me, check fluids and tires, Stabil in the tank preferably with non alcohol gas sold at one station. If the salt is off the roads I drive it. If not driven much, I charge the battery every month or two.
Re: storing car for winter [Re: ahy] #1513507
10/14/13 06:51 AM
10/14/13 06:51 AM
5thAve Offline
5thAve  Offline
Wax, vacuum, fresh oil. Then I just park and yank the battery and don't touch them till spring. Last year I had one car outside, I started it partway thru the winter but other then that I just kept the snow brushed off it.
Re: storing car for winter [Re: 5thAve] #1513508
10/14/13 07:48 AM
10/14/13 07:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
don't start the car unless you're going to drive it!!! (for at least a 15-20 minute drive to get everything up to operating temp)
unless you like to prematurely rust out your exhaust system, fill your engine oil with water, etc.
**Photobucket sucks**
Re: storing car for winter [Re: 70Cuda383] #1513509
10/14/13 08:01 AM
10/14/13 08:01 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
x2
you WILL get condensation in the crankcase and this will turn your engine oil into a milky brown color. better to crank it over by hand or let it fully warm up (so that any condensation will evaporate).
Re: storing car for winter [Re: DGS] #1513510
10/14/13 08:10 AM
10/14/13 08:10 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Same as above. You don't have to do anything over the top.
I do have battery tenders on all my cars. It really saves the batteries, and you know what you are working with when you go to start the car. Only an option if you have power close, though. If not, disconnect the battery.
383, Hemi 4-Speed, AlterKtion, D60
Re: storing car for winter [Re: Crazy68Dart] #1513511
10/14/13 08:50 AM
10/14/13 08:50 AM
SE PA
Yellow Fever Offline
SE PA
Battery tenders, PRI-G in the tank but that's year round and softener sheets inside to deter the mice. Start and drive them as much as possible on nice days.
Re: storing car for winter [Re: Yellow Fever] #1513512
10/14/13 10:10 AM
10/14/13 10:10 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I like the get the car completely detailed and then make sure it is completely dry before you put it in one of these!
http://www.carbag.com/buy/car_jacket.html
Admiration For Multiple Carburetor Vehicles...
Re: storing car for winter [Re: Stewpar] #1513513
10/14/13 10:18 AM
10/14/13 10:18 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
personally I take the battery out for storage and keep it clean and dry. if left dirty and condensation forms there could be a small draw on the battery through the dirt from post to post. I don't attempt to start unless it will be driven.
Re: storing car for winter [Re: carhunter] #1513514
10/14/13 06:36 PM
10/14/13 06:36 PM
Lavonia, GA
cjbill Offline
cjbill  Offline
Lavonia, GA
On my 300 'vert, I would put some Sta-bil in the tank, disconnect battery, and put plastic peanut containers of charcoal and Irish Spring soap inside...one to collect moisture, the other to repel rodents.
Re: storing car for winter [Re: cjbill] #1513515
10/14/13 11:03 PM
10/14/13 11:03 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Park it and forget it...
Re: storing car for winter [Re: moparcanuk] #1513516
10/15/13 12:15 AM
10/15/13 12:15 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It's cheap insurance and don't want to be the one to blame for someone ruining their gasoline but winter storage is short enough to go without fuel stabilizer.
I've had cars sit for 2 years and have no fuel problems. 5 months in a garage only requires storage on a full tank to avoid condensation in the tank.
Cars that do not make the mileage interval for oil changes should have the oil changed before storage. Contaminated oil should not sit in the engine for 5 months.
Re: storing car for winter [Re: Magnum] #1513517
10/15/13 12:40 AM
10/15/13 12:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I just haul mine south for the winter.
Re: storing car for winter [Re: rowin4] #1513518
10/15/13 12:05 PM
10/15/13 12:05 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Two years ago I winterized mine and put it away for the winter. Even with a few nice days here and there I didn't get it out since it was winterized. No more... If there isn't salt on the roads and the weather justifies it I drive it year round.
...FAFO...
Re: storing car for winter [Re: skicker] #1513519
10/15/13 02:31 PM
10/15/13 02:31 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Do they use the ice melt liquid n your area? They do in NE, Ohio. That stuff is really nasty and corrosive. I've always wondered if a good rain is enough to wash that stuff away.
