Re: Dumb Carboretor Adapter Question
[Re: mopowers]
#1512848
10/05/13 06:01 PM
10/05/13 06:01 PM
RapidRobert
Hold the eddie aqdapter up to side of the holley carb & see what you think. iirc one hole was slightly off & redrilling another one would have fixed that. What Stump said, see if it will locate the height of the throttle pin correct (or close enough) for the throttle cable/kickdown slotted lever to be right and that the arc of the movement in its' travel will be suitable also
[Re: RapidRobert]
#1512849
10/05/13 06:05 PM
10/05/13 06:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just use the right adapter. I never tried to mod one to fit the other. but they do not bolt up.
[Re: RapidRobert]
#1512850
10/05/13 10:35 PM
10/05/13 10:35 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Thanks Robert. I was wondering if someone has used the Eddy adapter on a holley carb. Guess I'll just have to see if it'll fit and worse case, I buy the holley one. No biggie. Thanks again.
